Mesh grille
Mesh grille
Anybody have comments about this mesh grille for the c-6?
https://www.americancarcraft.com/200...SAIEgJMJ_D_BwE
I went with a Racemesh grill in gloss black, turned out really nice. The PO had cut the original up to install his laser jamming radar detector so it needed something.
https://racemeshgrilles.com/CHEVY-C6...nce-_p_32.html
Install
2 years later
Install
2 years later
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,491 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Are you guys using zip ties to hold the mesh grill in place ?
jimmymack (05-16-2024)
I have the Racemesh grill and use zip ties.
Mine came with the black zip ties, but that didn't look good. I found some scrap thin steel wire that I cut into 6 in pieces, folded in half and used like twisty ties.
Vettelagged (05-01-2024)
I got this stuff, its actually Just Guttar guard you have have a piece for like 5$ its the same thing they send for side vents and charge you 30$. The Black V shaped supports have an open back (see picture)
You need to get under the car, the top has a lip you can fold the mesh over to hold it, at first i used 2 sided tape to try and hold the bottom up against the Black V supports, i also had a LED light strip helping sandwich it in. Changed the LED and my bottom popped out so i added some screws from the back twoards forward.
You need to find just the right size thickness/length screw but it works well and totally hidden, no zip ties!
leebay (05-09-2024)
Had one on my 2011 GS convertible. Was ordered from Mid America if I recall correctly. I thought it looked great. Very easy install. It used some small black zip ties that were barely noticeable to secure it in place.
The following 3 users liked this post by tommyc6z06:
NBVette_Canada (05-09-2024)
Anyone used the aluminum mesh grill from Top Flight Automotive?
