Oiled or Non-oiled air filters
I am thinking of adding an aftermarket air intake system to my 2006 C6 base. Which are better for for the 6.0 ltr motor, oiled or non-oiled air filters?
Most oil type filters, do not filter the air correctly until they get a little dirty, and an over oiled air filter, is a quick way to foul up the Maf sensor.
Also to point out, stock oem dry air filter does the best job of filter the dust out of the air, and already outflows the cars needs.
Hence with some oil type filters than have a higher flow rate (which is not needed, since again, stock dry filter is already outflowing the motors needs) even with the correctly amount of oiling, and slightly dirty to filter is best, still allowing a lot of trash through it over the stock dry filter as well.
So on a LS2 motor, problem is not the air filter system to begin with, but the intake manifold on the motor instead. Hence ls6 used lost wax to cast it, while the LS2 motors when to sonic welding of parts, and sonic welding did cause air flow problems itself. When they came out with the LS3 motors, had solved the sonic welding problems, and the LS3 intake manifold flow very well isntead.
So back to what will help, verse will be waste of money, just going through the Stock intake manifold to port it, or change it out to a Fast Intake, will gain you power, since again, LS2 problem with air flow restriction, is the intake manifold, not the air filter system in front of it.
Also to point out, don't need to go buck wild on the intake manifold, just need to clean up the runners and port match them to the heads, that makes a high difference. As for Fast intake, ends up about the same, but you pick up more mid range HP, since just flows better than a ported oem intake since internal jug section is smoother than oem intake.
PMPerformance (04-15-2024)
OP: I have my old ls3 intake assembly I’d be interested in selling.
It came off my car at like 30k miles. Filter was replaced shortly before removing it.
DM me if you are interested. As said above the ls3/ls7 intake really is the bees knees.
hawkgfr (04-16-2024)
Not going to work, since head intake ports on the LS2 and the Ls3 are different.
Hence the fast intake for the LS2, has cathedral ports to match the LS2 head intake port sizes.
So only way your going to use a LS3 intake manifold on a LS2, is to change the heads on the LS2 to LS3 heads.
QUOTE=Dano523;1607720954]Not going to work, since head intake ports on the LS2 and the Ls3 are different.
[/QUOTE]
I think he means the intake assembly before the throttle body, not the manifold. He mentioned the filter element being new.
[/QUOTE]
I am not sure you completely understand the post or response respectively,
We are talking about air intakes, not intake manifolds unless I missed something.
