Gauging interest: True Euro-spec LED tail lights.
Supporting Vendor
For years we've been struggling to find an LED tail light option for euro vehicles (which require an amber rear turn signal). Our best efforts have resulted in a modified version of the eagle eye tail lights but this only allows for one set of lights to be signal/parking, and the other to be stop/parking. To date, no aftermarket light provides simultaneous function of parking/brake and turn signal functions. Until now.
Using a variant of the Infirai tail lights, I've been able to incorporate a central LED light source that is of sufficient brightness to be safely used as a turn signal. This light source is an LED "hideaway strobe" typically used in emergency vehicles, but has an option for function as a bulb replacement.
TS only
TS with parking lights
TS with brake lightsPlanned options are:
Light options: (Base $250 price)
What do you think?
TS only
- Red lens
- Smoked lens
- 2 amber turn signals (outers only) +$200
- 4 amber turn signals (all 4 lights) +$350
- 2 amber turn signals/ two red fogs +$350
What do you think?
Good job!!! At those price points, I'm sure they'll be plenty of people to try them.
I'm sure I'm not going to be the only one that will want to see them installed on a car, so when possible, please post pictures.
I've seen Euro taillights on C5s before, they looked pretty good. I believe the bottom half of all 4 lights were amber. I think this is a much better look.
The only question I have, is this a plug and play with OEM harness or is there additional wiring?
Good luck!
Good luck!
Just clarifying ... are these for US-spec cars, or export-spec cars (since they used different rear harnesses) ?
Really looking forward to seeing them on a car.
Supporting Vendor
