Car Locked with FOB and Key in it
My wife and I live in a very safe, secure area. It might not be the smartest thing to do but I always leave my keys/FOB in all of the vehicles we own. The garage is attached to our home and our home is typically locked.
I uncovered the 06 last week and found the door was locked. I can see the FOB with Key attached sitting in the cup holder. I immediately went to the Key Closet looking for the additional FOB. It is not there. Not sure what happened to it, that is another mystery.
The hood is open with the tender on it. Tender is green indicating the battery is fully charged. Removed the Tender and checked the voltage, it is good.
Sent the wife to the local dealer with the Title to get a new key made. Got the key, it slid in the trunk slot, but it does not open the hatch.
Do I call a lock smith to break in? Please help with advice.
Retired & lovin' it!
In some instances, especially if the lock cylinder has not been used, it can bind up & be difficult to turn. Try squirting some dry lubricant (or even WD40) into the key slot. Let it sit for a minute or so & then try again.....use some more force than normal, but carefully.
Vettelagged (03-26-2024)
I was shocked at how easily the Lock Poppers guy got into it. All he did was take a small wedge to put between the glass and the weather strip, use a long pole with a hook on the end to hook the emergency release handle on the floor next to the driver's seat, and pull up on the lever to pop open the door. If someone wants into your car, it clearly won't take much if they know about that release handle.
The following 2 users liked this post by VetteVinnie:
Texasthunder (03-26-2024),
tommyc6z06 (03-26-2024)
Received 8,863 Likes
On the C5 all you had to do was shake the car if the fob was locked in & it would recognize/wake the fob so you could open the door. Did they fix this on the C6?
This is also one of the reasons I don't have auto lock activated on any of my vehicles.
The following 2 users liked this post by JABCAT:
tommyc6z06 (03-26-2024),
In fact, our C5 doesn't even have a passive lock feature since there's nothing to detect when you walk away from it. It was the same way when I had my 2003 Z06.
How is that even possible considering the C5 doesn't have an RFID fob? You have to physically press the unlock button on the remote or use the key.
I never owned a C5 but I always assumed it worked if that's what they were telling people.
Received 3,357 Likes
2023 C6 of the Year Winner - Modified
I'd try shaking the car. I know some instances the fobs can go to sleep... never leave it in the trunk area... made that mistake the first week I had the car. Worst case you may have to call a locksmith or tow company to open the door for you. You can baloon the glass out a little bit and get a rod in to pull the door release on the floor, its tricky but doable. (again ask me how i know lol)
CorvetteBrent (03-27-2024)
I bought 2 extra FOB knock-offs for $15 each on eBay (yes they work)....in-part to address this situation at home. They are kept in my extra key storage area.
About breaking into a car without damage. I have been serving in THIS AUTOMOBILE CHARITY since 1997. On occasion, we have to break into a donated vehicle because the only key was accidentally left inside a locked car with windows up. We use THIS AIR WEDGE and a long reaching bent rod to push door-lock buttons or grab release handles.
I keep one such air wedge at home in my garage tool chest, just in case, whether it be for our vehicles, or to help a neighbor.
Yeah the air wedge works but you have to be extremely careful, since the window indexes and tucks into the weather stripping it doesn't give it much play. then the next problem is that dosent leave you much room to get the rod in. The guy who got into mine had to damage paint in the process just because there wasn't room, I okayed it and couldn't really be mad at anyone but myself but... yeah they arent easy to break into lol
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
silly question, and doesn't help the OP...but, doesn't it drain the battery if the FOB is left in or close proximity to the car...as its trying to communicate to the RCDLR?
Sorry...I live in the stone age and don't have these communication snafus with any of my other cars (those can have keys/FOBS left inside when garaged ...unlocked of course)...just trying to understand more.
Last resort (if it's not a vert) is too remove the outside driver side tail light..... Drill you a small hole in the wall behind the light and fish you a coat hanger/wire in there and try to nab the emergency door pull. I have a safety pull made attached to that release behind the light. If the battery dies or FOB dies, I can get into the car. Tumbler under the plate is fubar btw.
blownbayou (03-26-2024)
Received 1,792 Likes
These fobs don’t communicate with the car unless a fob button is pushed or a car button is pushed. Also, if the fob battery died while sitting in the cup holder then it's as if no fob is in the car. Not sure about auto lock feature because I’ve got that enabled. If the door doesn’t lock automatically does the car still look for a fob when the door pad is pressed?
owc6 (03-26-2024)
The following 2 users liked this post by blownbayou:
CorvetteBrent (03-27-2024),
