Where To Buy Caliper Rebuild Kit
Hey All,
I'm falling short on being able to find the caliber rebuild kit. I have an 2007 with the Z51 option. So I'm looking for the J55 kit. I've called area dealerships as well as getting the GM part number. Everyone says they're discontinued and they don't have any in stock. Mine are looking pretty toasted but I don't have any noticeable degraded braking but looking to replace before it becomes an issue.
Example of the C6 J56 (GS/ZO6) option
GM PN:
Front: 19208030
Rear: 19208032
GM PN:
Front: 19208030
Rear: 19208032
Are they leaking? Are you looking to totally rebuild the caliper, boots and all? You can clean them up, inspect for leaks but if it ain't broke, I wouldn't mess with it. If it's leaking then yes, fix it.
Corvette_Dez (02-17-2024)
Not leaking but I do have a trackday next weekend where I've been told my brakes will be much hotter than a trackday at my "normal" track. The boots/seals are craked and don't look like they will hold up much longer.
Google search comes up with plenty of sources.... https://www.google.com/search?q=2007...t=gws-wiz-serp
Yup. I run TBA 4300 series rotors and Carbotech XP10/8 (front/rear). I haven't gotten them to fade yet with Motul RBF 600. I feel pretty good with my pad selection for the level of driving that I'm doing.
Received 3,066 Likes
hawkgfr (02-11-2024)
If you are going to rebuild the calipers yourself, do yourself a favor and pick up some caliper assembly lube. It is absolutely necessary for reassembly and smooth operation of the pistons until the brake fluid takes over. Plus, it makes reassembly so much easier. It's hard to find in a local parts stores though.
https://www.ebay.com/itm/314518055726?
Thanks for the info, at this time I'm not looking to replace the calipers. If I was, I'd probably do the "while I'm here might as upgrade"
If you are rebuild the calipers for HPDE type heat, then want to look at SS pistons, and high temp seals and dust boots that will take the higher heat without melting like the stock rubber ones.
https://racingbrake.com/corvette-1/
As for HPDE events with any R compound tires, need to upgrade the wheel bearings to skf race bearing, since the added cornering G load is going to kill the stock wheel bearing quickly from the add side load, and then regarding the rotors, need to ditch the drilled rotors, since will heat crack them, and switch over to a three piece slotted rotors instead. Hence the reason for the three piece rotor, it allow the inner spider to flex in the corners, and reduces the amount of pad kick out,and the rotors slotted, still allows for the pad off gassing, but rotors are not going to heat crack instead.
Bottom line, Z51 option car was factory built for autocross, and if car is going to be used for that, then fine in stock form, including the HD pads on it.
When going to HPDE with R com pond tires, now will have the pads a lot hotter, and need to work backwards from the higher temp race pads, back wards into the drive line instead.
Also to point out, the U claim shell calipers are not the best at taking heat to begin with, since with race type heat, the U is them bends outwards.
In the days of the C5 Z06 have the same U calipers, guys would not get even a year out of them, before they are bent to far open, that they have to be replaced every 6 months.
Hence the reason that the c6 Z06 calipers went to bolt together calipers (over just most pistons), since would not bend open like the U types.
