C6 driver door window/lock issue
hey guys. new to page. have a 05 base c6 with a driver door issue.
un able to get in through driver side, popped the trunk to release cable to get in, driver door wont unlock from outside or inside. also driver window wont work either. passenger window works on driver side controls. So much have power, i also hear the clicking behind the dash when i hit the outside pad, nothing from inside button or window. outside pad was replaced last year along with new window regulator and driver door actuator. what could be the cause of door and window not working?
Race Car Tech
Welcome to the forum. Sorry to hear about your door issue. If you checked all the fuses, and cleaned the door pad, etc, then there is a 99.9% chance that your driver door actuator has gone bad.
This can be accessed and change without too much issues.
Here is a video of the process
Diamonddave60 (02-04-2024)
