Lumbar support won’t deflate
Hey Guys….I have a base coupe, 2007. My drivers seat center lumbar support inflates but will not deflate. I replaced the lumbar switch on the seat itself with no luck. Is there a module that interfaces between the seat switch and the pump itself or is it a bad pump? I hate just to tear into the seat without some direction.
Race Car Tech
There is a lumbar Control module. Check the fuse for the heated seat, and if that is OK, then check the connector wires at the seat switch, then if OK and the switch isn't opening the valve in the pump assembly to deflate the bladders then pull the seat and disconnect the bladder from the pump and you will be able to push the air out. You can check the module wiring as well.
I have attached the connector and wiring diagram for the driver seat lumbar.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
