the gas leak smell
#61
#63
Technically, it's called a "Special Coverage Adjustment" by GM, not an actual recall. It covers 2007-2013 Corvettes. No mention of specific model differences, so I'd assume this would also apply to the ZR1, but I could be wrong on that.
https://static.nhtsa.gov/odi/tsbs/20...30551-9999.pdf
Interestingly, the 2015 C7 also had a recall on the fuel pumps.
https://static.nhtsa.gov/odi/tsbs/20...57680-1621.pdf
#69
So shop finish work 2700. They told Crack was so bad it leak into the wire harness and cause the weather seal to swell. Also it was almost disconnected. This was a first for them. No dealer stock. Had to order upgraded one from canada overnight.
CorvetteFan1953 (12-20-2023)
#71
I have never read about one of these having said problem….so it helps me sleep a bit.
#72
I live in Utah now and happen to have a great performance shop nearby that is replacing my smelly fuel pump in February.
#73
Here's some photos of the fuel pump replacement on one with an automatic transmission. The entire suspension/rear frame cradle, exhaust, rear end, and transmission have to come out.
The following 2 users liked this post by CSixDude:
235265283... (12-23-2023),
evoviiiyou (12-21-2023)
#74
I have a 2013 427 and I started smelling fuel recently. I just came across this thread and looked into my coverage. My car went in-service 8/12/2013. After speaking with Chevy and the dealer, my coverage expired 4 months ago and there is no extending of coverage or courtesy adjustment available so I guess it's a $3,000 repair for me.
#75
#76
After reading several threads and watching YT videos on the subject the analyst in me is looking for the common denominator in this failure but there doesn't appear to be one. Failures seem to cross all year models, mileage marks and daily drivers to garage queens. The only statement I found that makes any sense is that the root cause of the failure is caused by embrittlement of the plastic and is exacerbated by ethanol laced fuels due to GM using the wrong type of plastic during the pump manufacturing process.
My 2012 GS with 34K for miles has no issues but how long will I be lucky? How long before parts become unattainable at GM? Should we acquire all the parts today and build up a repair kit and put that on the shelf for a future repair?
Also, not 100% sure I understand the 1/2 tank of fuel not causing a fuel smell thing. Seems that almost always the problem is a cracked outlet elbow on top of the fuel pump that I'm assuming would leak whenever under pressure vice tank fuel level.
Still trying to figure out if my symptoms mean it's unlikely the crossover is involved (or the EVAP cannister).
Terrible how much work it is to get to all this. Design people should be forced to go do about 100 replacements to teach them a lesson in how serviceability should be considered in design. Not sure why something more like the C5 setup was not used.
Greg
#78
I suspect that age and vibration play a role but I'm betting certain runs at production had substandard plastic. The SWA points out a crack where the electricals connect which I believe should not be under any pressure. My theory is that if it's ONLY at the electrical and not the elbow that gas sloshing is spitting some out.
#79
The dealer is supposed to inspect that area around the electrical connector for gasoline but the cracks are at the elbow fitting as has been posted. This area around the electrical connector is simply an area where there should not be fuel but fuel will pool there if there is a leak. None of these are cracking around the electrical connector, it's simply the inspection point for the fuel. GM wanted evidence of actual fuel outside the system, and not just visual cracks (in the elbow) before they were going to pony up to fix it.
@ 3:45 into this Youtube shows where his electrical connector was at least not sealed. Not sure one could prove or disprove if fuel got out that way or not.
It's bad enough they are getting away with not fixing issues after 10 years as the older it gets the more likely you will have a problem. Bad plastic is bad plastic. I would also have wanted the dealer to disclose that it had "Special Warranty Adjustments" and that at least THIS one had NOT been executed on the car I was buying (before purchase). If I were GM I would insist dealers do that as a matter of course.
Shame on the NTSB for letting them not make it a recall or at least allowing them to put time/mileage limits in the adjustment. And huge shame on GM for the design fail and letting this issue basically give a black eye to almost the entire C6 line.
I still don't get why the problem disappears if the fuel level goes below 3/4 in that tank. Shouldn't the pump be shipping fuel out under the same pressures tank full vs tank almost empty and stressing the elbow the same? Is the tank itself supposed to operation under pressure?
At least 1 person on this forum fixed his by simply redoing the pump/tank seal with a new O-ring and locking collar.
#80
Naples FL
Gas leak fix for $26!
I am not sure if I just got lucky or am a outlier but about a month ago my ‘06 with 105k miles, started the gas fume smell after fill up and it seemed to get worse; at first the odor would go away at 3/4 tank but eventually as time me went on, it progressed to 3/8 tank before it would go away. I thought for sure I had all the symptoms of fuel pump elbow crack.
while researching, I came across a YouTube video that stated it was the gas cap as the cause.
i ordered an OEM new gas cap from eBay and installed it with 1/4 tank of gas (I had no odor before the install).
I immediately filled it up until the nozzle shut off and much to my surprise and delight it worked! No oder at all!!! In the past, I had the odor start to before leaving the gas station.
I even canceled my appointment with my local dealer that was to perform a smoke test on Monday!
also, the OEM gas cap has a new design from GM.
I strongly recommend trying a new gas cap as your first step in diagnosing the issue. U might be surprised!!!
