Help educate me on all things C6
#41
My 2 cents on the dry sump question. The stock setup with the air-oil cooler in front of the radiator is not a good design for the street. There is no thermostat and even in relatively hot South Carolina my oil temps would be around 160 unless driving very hard in the mountains. Even then it was hard to get it up to 200. So I put in a Dewitt's radiator with the oil cooler in the rad. This doesn't really warm up faster since the rad holds an extra gallon of coolant but it keeps the oil temps higher and much more stable. There are aftermarket thermostats that bypass the oil cooler until the oil warms up. Those probably do warm up quicker and definitely cost less but I didn't go that route and can't say how well they work.
I never let any engine just idle to warm up, much better to just drive gently for awhile. I always put the oil temp on the DIC and oil pressure on the HUD. I try to avoid pegging the oil pressure (80 PSI) gauge by keeping the revs down. It means a lot of short shifting (but not lugging) for about 15 minutes. I wait until I see at least 150 and preferably 160 oil temp before I stop watching the gauges and let 'er rip.
For me, I had to have a manual wide body coupe so the dry sump was coming along no matter what. The hand built motor wasn't really a factor but the forged crank is a nice extra.
#42
I let it idle until coolant is 180 + then drive gently then......
#43
Thats wild because there are soo many stock convertibles that are faster than 13.49 and have been for decades.
#44
Most of the time I get one run and am told not to run again. On Power Tour they seem to let everything run.I have seen 2 people in a dune buggy with no helmets and Shorts and flip flops go down the track. It must drive their safety crews crazy.
#45
Idling is not going to warm up your trans or diff and wastes gas. Not the end of the world but I'd rather drive off and wait for the oil to warm up. I don't take it 2 miles to the grocery store.
FAUEE (11-27-2023)
#46
It's in the front of the engine on the passenger side, look down low. At first glance not that easy to find. A light helps, once you locate it you'll remember where it is.
Post a pic.
One of the builders was named Don Henley. He used to post in the forum under the name Eaglei. He gave valuable insight about the engines they built at Wixom and reasons for the LS9 forged crankshaft.
Post a pic.
Thanks for the help and reminder I wanted to find this
The following 4 users liked this post by PMPerformance:
#48
Definitely looks like a road trip with reduced MPG. Might as well pack 2 bowling *****
#51
For the 2012 model year does the RPO U3U NAV Stereo have XM Radio capability?
#52
Received 1,185 Likes
A bit more XM info…
C6 Corvette Radios, 2005-2013
2005: This was the first year to introduce the MP3 player, DVD player and Navigation options.
2006: XM Radio is first made available for Corvette owners.
https://www.corvetteforum.com/forums...tion-help.html
#54
A bit more XM info…
#55
All 3 of my current Vettes are convertibles as were the two before them.
#57
Out with the old and in with the new so to speak. My all original 73 is being picked up this week by the new owner and my new to me 2012 Grand Sport is waiting on a transporter for delivery.
#60
BurntOut (11-29-2023)
