Advice for leveling up at drag strip & 1/2 miles.
Supporting Vendor
StayinStock (10-23-2023)
Did not say it did.
“Dialing down that reaction time and 60’ time these
two devices can play a critical role.”
Reaction times don’t matter if you don’t care about going
rounds and winning races.
60’ times play a big part in eventual ET/mph.
Making the car hook and get off the line consistently
Goes hand in hand with both of the above.
Just dropping this here... Good example of gettin' it done with a manual. Note the no lift shifts and how fast he's working the clutch. The gauges get out of synch with the sound due to the doppler effect I assume. Enjoy.
OP you definingly have a 9sec car...
https://youtu.be/G6dmAjbq3r0
I was thinking the same! The last time I had a good run at that track, I was at 645 whp and ran 10.89 at 137 mph. Now, I'm supposedly at +/-800 whp and still running about the same. Same thing at the 1/2 mile Indy Airstrip Attack. A couple years ago at 645 whp, ran 155 mph. Then this last August at +/-800 hp, I ran 156 mph. Granted, I was running in a strong head wind this last time at the Airstrip Attack. I know there's a lot of variables at play, but this has been making me wonder. Do I really have 800 whp or am I just not getting the power to the pavement? It sure feels fast as hell when rolling into it on the highway.
However, I think the reason is your stock gearing - the GS drops a lot of RPMs and power when you shift into 5th gear (a long overdrive) at around 150mph, whereas the Z06s are still at the top of 4th gear at the 1/2 mile line. At your power level, have you considered switching to the ZR1 transmission and ratios?
