rear hatch stuck
rear hatch stuck
i cant get the rear hatch open. would like to put the hard top back on the car. with the top in the back i cant reach around it to pull any thing take apart anything or figure out anything. i have already taken out tail light. fob dosnt work neither does back button or switch by steering wheel. even the key no go it seems my only option is the Chevy dealer @ $250.00 an hour
Received 1,792 Likes
The idea is to drain residual voltage from the various modules so that when you reconnect, everything reboots. Touching the cables probably hastens the drain, but leaving the cables disconnected for 10 minutes should do it as well.
Got uid0 (11-12-2022)
Also, there's got to be a fuse for the latch circuit. Problem is, I can't see anything on the fuse block labelled 'latch', just 'trunk. There are two labelled trunk, but the one in the lower part of the panel I think is for verts. The one under a separate cover on the right might be for coupes. Fuse panel is in passenger footwell.
lis (11-22-2022)
I have also read recently that a license plate frame was preventing the key from turning all the way. In case you happen to have a frame.
Hatch stuck.
That was me on the key not turning all the way because of the license plate frame. Key would turn but was not going all the way in so it wouldn't turn fully. Are you hearing anything when you press the fobs or button and switch? If not you must have an electrical gremlin or a loose wire.
good luck
good luck
Mine will open if I push the fob or dash button several times. When closing, it takes several tried, then it does not pull down completely. I have to then push down hard to make the rear interior lights go out. I do not know if it needs the new latch mechanism or what.
Hatch issue
This sounds like a mechanical issue with the latching assembly itself. Not too difficult to replace. 3 bolts. I don't know if it has any adjustment ability or not. Based on your description it seems like the latch is out of adjustment.
lol
Phil
lol
Phil
I had the same problem. Get a can of dry Teflon spray. Spray on the lock and after some wiggling, it will work perfectly and effortlessly. DO NOT GET THE SPRAY ON ANYTHING EXCEPT THE LOCK. The stuff is so slick that you can't remove it from the slightest rough surface and it is white so it is easily seen.
Check to see if anything is caught in the latch itself. I had this happen once and once we pulled the rag from the latch never had the problem again and also always made sure nothing would ever get caught there.
Looks like we may never hear back from the OP, but if he can’t get the hatch open, I’m not sure how he can get to the latch mechanism with the top stowed in there. A rag or something similar jammed in the latch could have happened, but how do you get it open if so? Maybe the OP can update us on the situation.
IM making progress. I got the hatch open, got the hardtop out, and unscrewed the latch but I still cant get it to let loose. I have pulled some stuff out of the latch area, hard plastic pieces, and i keep hitting the buttons, it makes the sound and motion, but will not release.
CorvetteSparky (11-19-2022)
I crawled in there on my back with a stubby screwdriver, and unscrewed the latch from the hatch. then pushed the hatch up. Now I am going to replace the whole mechanism or actuator " I actually think it is called an actuator" since it wasn't actuating. I went to the Chevy Dealer and asked them what they would do, and had them try to open it.
with your idea of something jammed in there, got me looking a little different into the situation. Thank you. I did find broken plastic pieces in the jam, from previous owner. I bought the car with the problem, actually quite a few problems, very bad car buying experience. No honesty from Auto Connection in Fairfield.
