Shifter Repair Time
I have not got it loose but I am going to try your idea and see if I can get lifted up enough to get at it. Thanks. I did try to just take the **** off but no luck.
I have removed them. After watching the video I have been stuck at getting the tombstone out as it seems there are two screws to remove there as well. I am going to try to lift up on the counsel without removing it per the above post. Been a busy week at work so I have not had much time this week. North St. Paul car show tonight. Anoka car show Saturday night and the All GM car show Sunday afternoon. shooting for Sunday late afternoon to try it. Thanks again for all the ideas!
https://www.youtube.com/watch?v=sxWp5z4GWyk
This has some pretty good info.
Thanks for any help!
T
Edit: Actually found my answer in a C5 shifter boot replacement video. The video above shows that you should gentle rip the boot out of the space around the gear position indicator. DO NOT DO THIS! Instead, the boot is glued to a plastic piece that snaps in place with 2 clips, one in front and one in rear. Simply unclip the plastic piece from these 2 locations and remove it with the boot material leaving the glue intact. Then when you reassemble, simply clip it back down. If you rip it out like the above video shows, you'll have to remove the plastic piece anyway and reglue it to the boot material. I wish I had known this before....live and learn.
T
1320#me (06-21-2022)
I just took mine to the dealer a few years ago and had them put in a new shifter. I think it was less than $300 for the shifter. Plus labor. It's been working great ever since. But good luck with yours. I almost did mine the way you are doing yours.
I know this probably isn't all that helpful, but this is what my 2005 looks like (without the selective ride control ****). IIRC, the first time I removed it, it came off VERY hard (so hard I thought I was going to break it) and the little green metal clips ended up coming off and falling down inside. After fishing them out and putting them back where they belong on the tombstone piece, I couldn't get them to snap back in. It was like they were too big for the holes. I ended up bending them just a bit to make them smaller. Now they are somewhat loose and the tombstone pops right off. There are 2 screws under there.
T
Looks like the screws at the back end of the console are covered by the tombstone, so my suggestion to remove them and the others to lift the console up and access the area from below won’t be possible. Mine was an 08 and didn’t have the tombstone to deal with. Those screws in question were in plain view. Sorry. I’m sure you must be frustrated.
Hello and thanks for the replies. It has been a busy Month but over the weekend I was able to clip off the tab. I could not get the tombstone to come off so I had to remove the counsel and glove box off as one which was not ideal but did work. My biggest problem was not being able to lift it up very far to unplug the Passenger air bag because of how it was installed as new. It is tucked up under a plastic plate for some unknown reason. I grew tired off laying on my back under the counsel and cut the wires and took the counsel out. I was able to get at the plug and remove it and soldered it back together! Good thing I have a lot of experience soldering with my RC trucks and cars...... Another fun hobby. After this it was very easy but the tombstone was not easy to separate even with it removed so I did not try very hard as there was no reason to. Thanks again!
