2010 grandsport brake pads
Hi Guys
Thanks in advance
What brake pads would you you use for replacement for on front and back.Not GM .
any part numbers .
thanks Mike
Thanks in advance
any part numbers .
thanks Mike
I can tell you that most on here will tell you to get the duralast gold from Auto Zone. That's what I used. If you are racing or other high performance racing, then you might go with something else. But I'd guess for the majority of GS owners the Duralast Gold work fine and will have less brake dust on your wheels.
I'm a big fan of stoptech, or powerstop.
Ceramics have no place on sports cars. If you want a ceramic pad, you should have bought a buick. Ceramics will reduce your stopping distance, your heats oak resistance, and have a breakaway thermal characteristic. You don't hear from people that exceeded the thermal properties of ceramics because they didn't live to tell about it.
A bit of an exaggeration, but ceramics when they reach their max working temp they just start to fully slide, vs operate at a reduced effectiveness like a metallic or similar pad. There so many good pads that are low dust now, there's no reason to go ceramic IMO, unless it's for something not at all sporty or towy.
dr_gallup (05-05-2022)
Carbotech 1521 pads for me
expensive but made in the USA, lower dusting
and the fall out is not corrosive.
initial bite is almost identical to stock pads and
ive never had any fade in them
cyclesailor955 (05-07-2022)
Hawk HPS – High Performance Street Compound one piece pads
About 90% reduction in dust, no loss of bite, never fade even with serious mountain driving and significantly cheaper than the carbotechs. Get ceramics if you drive like a grandma.
Front Part#: HB658F.570
Rear Part#: HB659F.570
sonik_fury (05-07-2022)
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
Part numbers for C6 ZO6 and GS are below.
F: CT1185-S $290.00 Less 5%
R: CT1185R-S $246.00 Less 5%
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Great info on here and I appreciate the detailed explanations about Ceramic pads. I went with DuraLast Gold pads on my current GS and previous GS to reduce dust. WOW, brake dust is non-existent with these pads. But something I didn't give much consideration to is the reduction in stopping power. I avoid stopping aggressively during normal driving and I don't tailgate. But having greater stopping power is certainly a good thing since the car is more than capable and we don't know when someone is going to pull out in front of us, etc.
It would be interesting to see any 3rd party data that shows the difference in stopping distance.
Having said that, each of us has to weight our own pros and cons and decide if we want to spend $100 on a full set of DuraLast Golds or spend $200-$400 or even as much as $600 on pads to get the maximum stopping power possible.
Powerstop z23s are like... 100 to 150 bucks an axle. They stop great and dust a lot less Han the ferodo factory pads. FWIW, ceramics pads do dust, they just dust smaller whitish clear dust. It makes the dust less noticible, especially on silver or chrome wheels.
Current price on Z23 pads at Rock Auto is $83 front and $59 for rear which are "Carbon Fiber-Ceramic" pads. $142 plus tax and shipping. So these are only about $50 more than the Dura Last Gold(+ shipping). I'm assuming that this pad is better than the standard Ceramic DuraLast Gold.
It looks like current price on the Hawk HPS is $219 front and $146 for the rear at Zip-Corvette(I've never used them). $365 plus tax and shipping.
FAUEE (05-07-2022)
While we’re discussing brake pads, what would be the best choice for a GS that is street driven, but is also used for an occasional HPDE event?
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
The GS uses the same brake pads as the Z06 (J56 brakes)
If you want the cleanest pads that work just fine on a street car that is not seriously tracked, get a set Autozone Duralast Gold
And a plus ... these pads are not expensive.
Set of Front Pads: - DG1419
Set of Rear Pads: . .DG1419A
Adam@Amp'dAutosport.com (05-07-2022)
That said, the oem pads are ferodo 2500s, so they're also pretty good for this use. I've heard good things about dura last GT, and powerstop z26 (same compound as z23 but with a stainless steel plate for thermal properties).
GS only street driven, melting the Duralast ceramic pads at the inner hub surface.
So you want to use the in the Duralast pads on the base JL9 brakes for street cruising, go for it since they are pretty much the same as the OEM ceramic pads on the car.
Z51 option base, GS, Z06 and ZR1 that have increased braking force, don't even think about it, since there is a reason that all these models came with HD higher working temp range pads to start with.
Hell, the best upgrade on the JL9 brakes, is to swap out to a set of HD pads to start with. This give the brakes better initial bite, better pedal feed back, and the higher working temp range of the pads as well. As for stopping shorter, that really comes down to the amount of tire grip in play.
So again, GS is wide body car, has more tire gripping force than a base car due to the wider tires in play, and why is will melt the duralast pads when you try to use them, even for just street driving.
The following 3 users liked this post by Dano523:
