Brake dust
Brake dust
I can’t take the brake dust anymore. Every time I take the car out the wheels load up with brake dust. Between that and the rear fascia getting dirty and dusty every time I take a ride! I have an 06 z51 not looking to upgrade rotors and all that. Car has 21,000mi so are there pads out there I can change to to avoid this and keep my sanity? Lol. Thanks all!
Duralast Gold from AutoZone are excellent pads with low dust, low noise, and a very affordable price.
The following 5 users liked this post by BluegrassMotorsport:
2008 Corvette (05-02-2022),
cmonkey713 (05-03-2022),
jbc1995fb (05-02-2022),
RayCE (05-05-2022),
USA1LBvert (05-03-2022)
Received 1,637 Likes
Ceramic brake pads. I also went with the Duralast Gold Ceramic brake pads from AutoZone for my GS. Solved my brake dust issues.
The following 3 users liked this post by TorchRedFred:
Yes, ceramic brakes do the trick. I put AC Delco brakes on my 07' C6 with Z-51 code and they work fine with very little dust. I don't track my car, however, the braking is just fine.
The following 2 users liked this post by sramzzz:
BluegrassMotorsport (05-02-2022),
A trip to autozone is in order I guess. Duralast gold seems like the pads most recommend. Thank you all!
Duralast Gold for me as well.
The following 3 users liked this post by Corvette_Ed:
Received 1,681 Likes
Ceramic brake pads is your answer.
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
Part numbers for C5/6 Base and Z51 are below.
F: CT731 148.00 Less 5%
R: CT732 128.00 Less 5%
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Landru (05-05-2022)
dar322 (05-04-2022)
Do those ones squeal as bad as the stock brakes? I’m tired of the dust but not willing to sacrifice safety with ceramic pads if possible. I know there’s give and take, but I could put up with the squealing as long as it’s not worse.
My factory pads squealed and had tons of dust. The Hawk pads are very quiet, very low dust. I put on new rotors and they are still smooth.
To temporarily get rid of squeal get up to 80 and make a couple HARD stops. Deglazes pads and rotors. It will come back though.
I've been doing brakes for almost 50 years and I've tried almost every major brand and I will only use PowerStop. I put them on my C6 GS Callaway and the improvement in braking is unreal and no dust. I do get a slight squeak when I first pull it out of the garage but that's all. I switched the Corvette soon after I bought it and it only had 12k on it. Do a hard stop from 130 and you will nearly pass out they pull so hard.
Seems like powerstop,hawk and duralast gold ceramic seem to be the most popular. I assume all these brands are ceramic? Honestly anything has to be better than the stock pads. I can’t drive one block and the wheels are caked with dust.
This is a great thread. I have the ZR1 wheels and EVERY time I take the car out I come home with brake dust loaded on the wheels. I still have the original pads at 9500 miles on my 427 vert.
Stupid question but I can change the pads without turning the rotors?
