Damaged dash repair
Damaged dash repair
Hi all,
I'm looking for advise on how to fix the following crack in my dashboard. I think the material is fiberglass….? What is your advise on the best way to repair this section? The center console trim mounts to this and the radio screws to it, so the repair needs to be solid.
thanks!
thanks!
Received 1,597 Likes
I would try to plastic weld that, I have done that to several similar dash pieces in the past.
https://www.harborfreight.com/80-wat...9a7dc1172b402a
killain (10-07-2021)
My go to has always been Fast setting JB Weld.
billmoore48 (10-10-2021)
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Well I'm drawn to the plastic welding, but I fixed my headlights using JB Weld. How much weight or movement does this part get ?
What I like most about plastic welding is the ability to add material to the repair area, making it even stronger than before.
I to say JB weld epoxy.
The following 2 users liked this post by madsonp:
billmoore48 (10-10-2021),
TCW (10-10-2021)
JB Weld it and your done. I wouldn't use anything else. It can even be filed down after completely cured. Best epoxy on the market for these types of jobs. Not the clear JB - the original hard as steel JB, I like the quick setting. Put it on both sides and either hold it for a couple of minutes for it to set or tie wrap them together and let it cure for 24 hours and it will be good to go.
ccryder (11-02-2021)
Oldtimer
Well in that case, I think like the 'Loctite' product might be a better choice, there isn't very much room for you to get the "Plastic Welder" in those tight spots and that would just leave an unfinished bond. and that does you no good at all.
Good Luck !
Good Luck !
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
I would take it to a professional! Someone who is an expert on interiors! Done!
killain (10-10-2021)
thank you all for the replies and guidance! Now to install the new dash!
I think it is a plastic material, I went the route of using gorilla glue and then plastic welded it! This way it’s sealed in the middle out and then reinforced with the plastic weld that smoothed it out. It’s probably stronger than the rest of the dash now! I also cut the holes for the 12+ dash tweeters while I was in there.
12 tweeters ?
