Brakes Squealing - Need Advice
Hey all,
I need a little help here. I recently purchased a 2008 vert base and have noticed the brakes squealing. Obviously, the initial thought was squealer tab on pads, but this only had 4k miles......not since last brake service, but total. I have put more grease on the pads but it did not help much. Is this a known issue? What are the recommendations...new pads, new pads and rotors? If I need to switch out the pads, what are the best pads to make the brakes silent?
Any suggestions are welcomed!!!
Thanks!
Tony
Thanks!
Tony
Received 8,871 Likes
High performance pads have tendency to squeal especially when cold. Your owner’s manual says this is normal. With the car having such low miles, you could go through the brake bedding procedure to see if that eliminates the squeal.
https://brakeperformance.com/bedding-in-rotors.php
JABCAT (08-12-2021)
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech 1521 brake pads will eliminate noise and dust.
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
Part numbers for C6 are below.
F: CT731 $148.00 Less 5%
R: CT732 $128.00 Less 5%
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam@Amp'dAutosport.com (08-12-2021)
Hey all,
Thanks!
Tony
Thanks!
Tony
Sure hope you didn't actually put grease on the pads.
Supporting Vendor
I appreciate the business tracking number will be sent in a few hours..
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Lot of people on this forum recommend Carbotech, AutoZone Duralast Gold brakes, Akebono Pro ACT.
I used Akebono Pro ACT on my previous 13 corvette with J55 brake package, eliminated squealing.
I am sure you will be happy with Carbotech.
appreciate the feedback. I ordered some carotech pads yesterday.
I want to thank you guys for all the great detailed information. The Delco 17D8 pads have a CF letters of FF which I need to improve. With all the info that was passed on to me, with a little research I should be able to get better braking. Thanks again.
Ed
Ed
