Glove Box Handle
Glove Box Handle
The glove box opener on my 2006 broke in half today. Is anyone printing these? If so, how can I contact them. If I can't buy a printed one, can I get one from Chevy? Don't want to buy a used one as it will probably be fatigued like mine was. My interior is tan/beige.
Also, how can I open the glove box door?
Thanks for any information.
Received 4,508 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Try this place first, they just might have what you are looking for your Corvette!
https://aescorvetteparts.com/collections/corvette-c6
Norskie (06-22-2021)
Received 1,798 Likes
Received 8,899 Likes
Custom Install Parts Black Glove Box Compartment Door Latch Lock Handle Compatible with Corvette C6 2010-2013 https://www.amazon.com/dp/B078PYFXL4/ref=cm_sw_r_cp_api_glt_fabc_G4T47ZX7HBQ0 NQJ1ZGHA
Norskie (06-23-2021)
These replacement handles run about $55-62 depending on where you find them. Make sure you order the proper color. You can open the glove box with the handle broken by pressing upward on the glove box door to take the pressure off the locking mechanism while pulling down with your fingers or your thumb on the metal rod that sticks out of the handle mechanism. It's a nuisance but it does work. I haven't seen GM improve on this design so I've been waiting for that to happen before ordering (may never).
Not sure I'd want to buy OEM and deal with it breaking again after a short time. Right now I have mine held together with a paperclip and some JB Weld, but I will probably buy this: https://www.ebay.com/itm/2005-2013-c...0AAOSwEFheRFC5. The seller has good reviews at least and claims a lifetime warranty. I haven't ordered it so I can't speak to the quality of it, though.
I can appreciate that someone is trying to make a different design, but in my case, the handle itself is what broke and I don't see this aftermarket design having a stronger handle.
When mine broke I looked online but refused to pay $55 - $75 for a new brittle piece of plastic with a stiff spring that will likely break again before long. So my solution was to use a piece of bootlace. It ain't pretty but it hasn't failed and hasn't made a sound in 6 years.
RobJoy (06-25-2021)
