Oil Pressure pegs when cold
Noticing my oil pressure pegging when engine is cold almost 80 PSI when I accelerate. Comes down to 35 40 if I take foot off pedal. After it heats up it stays in the 30 to 50 range. Running mobil 1 and a GM oil filter. Anyone else seeing this ? 2013 GS .
Thanks for any feedback.
Dry sump? It's normal. I keep the engine speed down until the oil gets up to 150-160 degrees.
The following 4 users liked this post by dr_gallup:
Totally normal. Simple Chemistry/Physics; colder oil viscosity is higher. More pressure needed to circulate oil. As oil rises to normal operating temp, oil pressure drops to normal range.
