Floor jack
#41
Have a Pittsburgh (Harbor Freight) LOW PROFILE rapid pump 3-ton garage jack. I like it because it is low profile and I can get it under the car and reach the C-6 front body jacking point without first using a small jack to start the lift. Some jacks with a standard clearance will not go under the C-6. I also have the pucks made from a eye bolt and hockey puck (eBay, I think). They are a lot better than the plastic kind that the ears snap off so easily.
#42
I agree. I've used mine on multiple cars and they are great for doing things like brakes if you want all 4 wheels off the ground at the same time. I worked with hydraulic jacks for a while, but if you don't have clearance in the garage in front and sides for the jack and long handle, it can be a pain.
The following 2 users liked this post by NLPed:
wideglideleon (11-02-2020),
wjnjr (10-31-2020)
#47
I've had a 2 ton Norco floor jack for 30+ years, but picked up a low profile Pittsburgh aluminum 2-1/2 ton race jack the other day. I have yet to unbox it. I intended to buy a bottle jack as well, but Harbor Freight was out of stock on them. I was told they're redesigning their bottle jacks and the new ones won't be available until some time in December. I ordered a 12 ton Torin bottle jack online.
#48
Here's a $59 coupon good until 12-3-2020 for the Harbor Freight 1.5 ton aluminum racing jack. Merry Christmas :-)
https://www.harborfreight.com/15-Ton...y_LzZjHAI_an3c
