Lightning strike 20 feet away now having crazy problems. 2008 help!
Hey guys; lightning hit about 25 feet away from 2008 c6 and ever since then I’ve had some really bad problems with it. I could use some advice. Everything worked PERFECT before this happened and it’s a really nice low mileage under 50k c6. I believe the trickle charger was hooked up when the strike hit because the car is not driven much. I am not 100% sure though.
First issue: the cooling fans no longer work, so the AC stops blowing cold and the car overheats and isn’t drivable. So it’s basically been parked.
second issue: the battery drains very fast over night fast even on a trickle charger. Some kind of major draw. I can measure 12v on the battery after I charge it up, disconnected, which will get the car to start up. But when I leave it over night it will drain down again. It also reports a much lower reading on the voltmeter when the car is hooked back up to the battery. Making me think it has a major draw.
third issue: when I unlock the doors with the key fob, I can hear a pretty loud popping sound from the hatch area like the rear lid is opening, but it does not. It does open the rear hatch normally but the sound caused when simply unlocking the doors is new and alarming.
Looking for some solid advice here. I’m normally a diy’er but this one has me pretty wary. Thank you guys.
Maybe it just fried the battery and the bad battery is causing the other weird symptoms. First place I would start is to try a different, known good battery.
Sounds like you have some serious electrical problems. I would check the codes to see what they indicate. A lighting strike produces thousands of volts and amps easily destroying every electrical system in its path.
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
The following 2 users liked this post by Turbo6TA:
Fast Dawg (10-04-2020),
Lonestar13 (10-05-2020)
Fan 1 control circuit
And after you get finished replacing the battery, pull all the various fuses 1 at a time and replace any that are burned out.
Don't forget the fuses under the passenger compartment kick panel too.
Received 1,796 Likes
If the 12V reading is accurate, then your battery is considered to be essentially discharged at 25% of its full capacity. That in itself would cause any number of electrical gremlins. A fully charged battery should read 12.6 volts. If the battery charger was hooked up during the lightening strike, it's quite possible that the charger has been damaged, and unable to fully charge the battery. If you measure the voltage when the charger is connected, you should see something like 14.5 volts. Have you investigated that? As another comment, I don't see how a momentary high voltage spike could fry a lead-acid car battery. They're pretty robust. And the charging cable from the charger would be something like 12 gauge at most, good for 20 amps, so if the charger tried to pass a significant part of the amperage from the lightening strike into the battery, the cable would have vaporized. I'm guessing that didn't happen.
Again, the easiest item to initially verify is the battery and low battery voltage is a known source of many gremlins.
Update: Advance said the battery is dead-dead and replacing it free under warranty. It’s only from late 2018.
Doubt it will resolve everything but fingers crossed. Will update when I know.
You might want to get the charger checked out before you hook it up to your new battery.
ledesordre (10-03-2020)
New battery charged up and on. As soon as I connect the battery I can hear a thud from the passenger side door area (possibly lock mechanism).
sometimes when I unlock it with the fob I get a loud pop from that area but it’s hard to replicate (again this never happened before the lightning incident)
the cooling fan is still not coming on and still kicking me the same code as listed above.
Again ... check all the fuses in the car ... won't take much time
A few years back we had lightning hit the satellite disc that was mounted on a corner of our roof, scared the heck out of the wife as she was home at the time..
It fryed the disc, all of the boxes on all of the tv's and took out the battery tender I had on the Vette and the battery was shot and it was only 3 months old!
We were lucky did not damage any of the TV's and did nothing to the Vette other than the battery and no damage to the house or any of its wiring and nothing to any appliances.
Had the satellite company come out and replace all of their equipment and the guy said he had never seen anything like it before.
crazy man. Yeah it hit closer to my neighbors house and she was looking at 20k in damages. I lost a lot of outlets, appliances, and electronic devices too, including the circuit board on my furnace. I didn’t even know the vette had issues until this week because I drive it so rarely, although the strike happened in the first week of sept.
