Definitive Fix to C6 Roof Rattles
My 2008 Coupe has had roof rattles for years. I followed every single thread, every single fix,and sought advice to the eliminating the roof rattle and all to no avail.
I tried the "fix" described" in the attached video. IT WORKS ! 100%
Purchased two sets of O-rings, #31 (9/16" OD and 5/16" ID) and #5 (3/8" OD and 1/4" ID). #31 replace the current O-rings on the roof guide posts (see video), and then added the #5 O-rings onto the posts as well (again see video).
Before fix: rattle, rattle, rattle. After fix: silence, silence, silence.
No exaggeration. You will be shocked.
https://www.google.com/url?sa=t&rct=...srjAJWPtGC1RjH
I disagree. Nothing and I mean NOTHING permanently stops roof noise forever, especially if you take off your roof occasionally. I've done o-rings, e-clips, latch tightening, and lubrication. Nothing lasts.
I bet it will do pretty well if you replace said O-rings that the OP listed periodically.
Received 1,798 Likes
sd45t2 (03-20-2021)
Just passing this along as a courtesy. If you don't want to try it, then don't......
BTW, used Synthetic Lube for years. Nice stuff. Didn't completely solve the problem.
P.S. You can add a little Synthetic Lube or Teflon Lube as well after the O-rings are added/replaced. Just in case.
sd45t2 (03-20-2021)
sd45t2 (03-20-2021)
I did the O rings, shrink wrapped the pins and added C clips 6 years ago. Silent ever since and I take my roof off a lot.
I have never greased up the weatherstrip because it just sounds like a mess and in my case, clearly was not needed.
I found all 3 fixes on here years ago and it has been a permanent fix on my car, even with removing my roof about once per week. Not sure if any one or all 3 together did the trick, but until I see a thread like this, I don't even think about my roof as a problem.
TecCrash (10-01-2020)
I ran by Home Depot last night to get the o-rings.
If I get the COVID from all the unmasked folks there but fix the roof rattle it will have been worth it.
If I get the COVID and don't fix the problem I'll come looking for you VETTRAN4 and cough on you.
Saw the video/did the fix - was quiet for a few days, but now minor pops and squeaks are back. The most obnoxious loud pops/bangs are gone. Planning on lubing the pins next, maybe pull the latches/clean/re-install as others have done. The O-rings do work but YMMV.
Received 2,062 Likes
I put 1 or 2 drops of sewing machine oil on the axles the rollers rotate on, with a bottle that has a needle like a hypo. It usually lasts 20-30 thousand miles (2-3 years) until it dries out.
Here's all I use. Works for me. Recommended to me by Pat G. the camshaft guru.
https://www.amazon.com/Equipment-TEFLON-LUBRICANT-SEALANT-Filter/dp/B01M6DPMLM/ref=pd_lpo_86_t_1/146-1189846-4719266?_encoding=UTF8&pd_rd_i=B01M6DPMLM&pd_rd_r=fbc6649e-111b-427e-be65-fdaae2e1965d&pd_rd_w=PLbWi&pd_rd_wg=reWkx&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=9YY0NGR79RSRD4W3B24N&psc=1&refRID=9YY0NGR79RSRD4W3B24N
