Moog endlinks lasted about 5,000 miles of summer-only driving
Moog endlinks lasted about 5,000 miles- what went wrong? Should I trust Moog a second time or do I use a different brand/OEM? I know a lot of people use the Moog replacements here, but I want to get at least one full season out of them. Granted, I do live in Ohio, but our roads aren't *that bad*
2008 base with Z51 swaybars
Jeez, I needed end links up front and read so many good reviews here on Moogs so I went out bought them and installed them a few weeks ago. Much more substantial in hand compared to the OE pieces. Any chance the ones you got are knockoffs?
How did the ends fail?
Break, bend, ball & socket component, lubrication issue, other?
Stock alignment, stock ride height?
Upgraded sway bar install error?
Summer driving implies failure was not to dirt or debris.
Landru (07-07-2020)
I haven't removed them yet but I'm getting the same clunking familiar with bad endlinks. Stock ride height, good alignment, etc. All I can think of is maybe exceeding the torque specs (I did it by hand and I was firm)
Have you tried an email to Moog's CS?
Ask MCS if 5K is their normal duty cycle.
See what they say.
Might be a 'bad' batch Moog's aware of, might just send new ones on their dime.
Great way for Moog to promote their product(s) is extending some goodwill when merited.
Like now.
See what they say.
Like now.
Received 2,898 Likes
Did you get the ones with grease zerks?
Had mine on for over 100,000 miles. Give them a pump of grease yearly.
Don't know about the sealed ones.
GL
GL
Same thing happened to me, they were greased appropriately and still started clunking.
Went with Pro-forged and was very impressed, quality pieces and no more clunks, similar mileage to the MOOGs at this point.
I just completed installing moog sway bar links on my '08 within the past hour and I see this post. Wow. I ordered mine from amazon and had to return one because the grease boot was defective. Taking a break before I take it for a test drive. Time will tell how they hold up. A loose axle nut can cause a clunking noise. Good luck.
Yeah. Post up a pic. I've been using the MOOG greasable endlinks (Moog K750136 Stabilizer Bar Link Kit) daily for ~60K miles without issue. Always laughed at the non-greasable "silent" endlinks for hundreds of dollars CorvetteTax at it's finest!
Bought Moog endlinks for a Lexus I had once they were total trash. Very poor quality grease seals kind of looked like something that should be on a garden tractor. Stay with OEM.
Received 1,120 Likes
GM replaced all 4 links at 31k with an improved design while under warranty. At 55k, one rear started acting up.
Had read that name brands links were still prone to early failure. So I went with no-name O'reilly Auto parts cause they have a lifetime warranty. Figured I could just swap for free as needed. Haven't had to yet. Have 88k now.
Received 2,062 Likes
h8snow (07-11-2020)
I wore out 2 sets of those in under 80,000 miles. The nylon bushing wears out. They were quiet up till then.
I don't drive mine that much but I can see where that could be an issue. There is another version that does not have the nylon. I wonder is these would be "noisy" or not quiet. We used the aircraft heim joints on the race cars with no ill effect but who cares if they are noisy on a race car.
