'06 LS2 surging - MAF/intake issue?
Old 05-21-2020, 05:50 PM
Matticus91
Matticus91's Avatar
Default '06 LS2 surging - MAF/intake issue?
My 2006 LS2 6mt car has been having issues with very subtle surging on light throttle input. I believe I have narrowed it down to an issue with the MAF or cold air intake as unplugging the MAF fixes the issue and overall improves the feel of the car dramatically.
Has anyone experienced this before, and if so what was your solution? Only current mods are SLP Blackwing CAI and 1-7/8th headers with a tune from Doug at ECS.
So far have done the following:
  • Smoke test and found zero vacuum leaks.
  • Cleaned the MAF
  • Checked all hose clamps before TB
Update! I manged to get a my hands on a stock LS2 intake and swapped it on to test the intake theory. It is 100% better now, zero surging and no other changes made.
This issue has been confirmed by many now to be attributed to bad airflow hitting the MAF caused by aftermarket intakes.
Old 05-21-2020, 06:01 PM
BadAV
BadAV's Avatar
Received 2,711 Likes on 1,720 Posts
Have you cleaned the MAF with MAF cleaner yet? That's step one, along with making absolutely certain all of the connection points between the filter and throttle body are tight and not sucking air.
Old 05-21-2020, 06:11 PM
Matticus91
Matticus91's Avatar
Yeah should have put that in the op, just added what I've done so far (maf clean, smoke test, hose/clamp connection check etc).
Old 05-22-2020, 07:58 AM
Dano523
Dano523's Avatar
Received 3,054 Likes on 2,196 Posts
Stock cam, or some wild aftermarket cam that is causing the surging all on its own low rpm instead?
Old 05-22-2020, 10:11 AM
Matticus91
Matticus91's Avatar
As I said the only mods are CAI, headers and a tune
Old 05-22-2020, 10:45 AM
irok
irok's Avatar
small exhaust leak sucking in unmetered air
Old 05-22-2020, 11:36 AM
Matticus91
Matticus91's Avatar
Exhaust leak sucking in air? What near the headers or something? I don't think that's it as I've had the headers on and off with new gaskets since the issue started and no change, but I will definitely check the gaskets and bolt torques
Old 05-22-2020, 11:12 PM
irok
irok's Avatar
Exhaust manifold gasket at the cylinder head.Once at WOT will clear up as car goes into open loop and ignores data from 02 sensors.Did you use the factory multi layered steel gaskets?Check your 02 sensors pigtail and any extensions for damage
Old 05-23-2020, 10:21 AM
Matticus91
Matticus91's Avatar
Shouldn't that give a code? And yeah I used GM multi layer steel gaskets.
Old 05-24-2020, 03:50 AM
irok
irok's Avatar
The 02 sensor's should set a code but sometimes no codes present
Old 05-25-2020, 09:34 AM
FactoryZ51
FactoryZ51's Avatar
  • Cleaned the MAF
could be your ignition coils. I replaced mine after 16 years on the oems. Found new inexpensive oems on ebay.
Old 05-26-2020, 09:23 AM
1RFLMAN
1RFLMAN's Avatar
  • Cleaned the MAF
Could be something in the tune causing the surging isue. Upload the stock tune back into the ECM and test drive it to compare driveability then... can't hurt.
Old 05-26-2020, 09:36 AM
Matticus91
Matticus91's Avatar
Updating OP now - I got my hands on a stock LS2 intake from a local owner and tested. Everything feels MUCH better now, zero surging. All of it was caused by the intake.
To '06 LS2 surging - MAF/intake issue?
Quick Reply: '06 LS2 surging - MAF/intake issue?
