★Quiet Down Your 05-13 Interior in Seconds!! /BLOCKIT® Sound Deadener- Forum Special
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Use The Coupon Codes Below & Save an Extra 10%
★ BLOCKIT® "Quick & Quiet" Mats- Coupe
Fits All 05-13 C6 Standard/Base, GS, Z06 & ZR1
Get rid of unwanted noise in your interior in SECONDS with the BLOCKIT®"Quick & Quiet" System!
The BLOCKIT® "Quick & Quiet" mat is the fastest efficient sound deadening system available. It installs in SECONDS!
Simply place the 3 piece kit right on top of your existing factory carpet! One piece for the cargo area and one piece for behind each seat.
All pre cut for a perfect fit! The patent pending design absorbs and suppresses unpleasant noise that leaks into your interior.
This is NOT a thin single layered mat. The BLOCKIT® is a combination of 4 layers of real acoustical soundproofing. All automotive grade. . FMVSS-302 Tested & approved!
Now with even MORE barrier for more noise reduction.
The layers are held together by a unique infused processed which requires no glue, so there's no chance of separation! It measures 1" thick! It can compress down to 1/8" so you lose NO cargo/trunk space!
It helps reduce tire, road noise and some aftermarket exhaust. But not to worry your exhausts sweet note will still come through when you get on it..
Great for Blue Tooth. Allows you to have a comfortable conversation. Helps reduce driver fatigue that occurs on long trips.
The BLOCKIT® also helps reduce heat and keeps your cargo area cooler.
Since there is no adhesive, you’re NOT permanently gluing a ton of heavy weight to your car. Take the Blockit out for track events. Install for the ride home. The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
Made in the USA!
Raw materials are from the USA!
Constructed under strict ISO 9001-2008 standards!
Granted a Patent by the USPTO
Picture below shows the piece behind the seat. Undetectable once in position.
(C7 used here to demonstrate)
Retail Price $229.95 - Use The Coupon Code Below & Save an Extra 10%
★TO ORDER The BLOCKIT® "Quick & Quiet":
Use the coupon code: blockitc6" and received a corvette forum 10% off special!
Click Here!
___________________________________
DO YOU WANT A LITTLE MORE NOISE REDUCTION?
★ BLOCKIT® "Quick & Quiet" Mats Plus DeadMat- Coupe
Fits All 05-13 C6 Base, GS, Z06 & ZR1
As you can see by the comments below the BLOCKIT® "Quick & Quiet" works great.
But some want just a little more deadening/damping but again, without the install hassle. We got you covered!
This kit comes with 2 18x32 DeadMat pads which easily go under your carpet behind the seat. Nothing to remove. The carpet behind your seat comes right up. Simply apply the DeadMat and put the carpet back down. Easy install. This kit simply takes it to the next level .
This kit sold separately costs $299.90
Combo Retail Price $285.95. Plus use the coupon code: blockitc6deadmat for an additional 5% off
★TO READ MORE AND/ OR ORDER the BLOCKIT® "Quick & Quiet" with DeadMats:
Click Here!
________________________________________ _
But don't take our word, hear what Corvette Forum members who purchased it, think of the Blockit.
Hey, just a quick shout out for a good product. I installed this in my '16 Z-06 and I'm very pleased with the product quality and sound. I still clearly hear the lovely rap of the exhaust, but not a lot of the tire noise on our nasty worn roads. Very pleased with this product.
I installed the 3 piece system and finally got a chance to do a test drive this evening. I was very pleasantly surprised how well it worked as the improvement was immediately noticeable. The noise level inside the cabin was reduced and I had to lower the radio volume since it was so much easier to hear. I can still hear the nice sound of the engine & exhaust, but without the annoying road noises. Very pleased with this purchase.
I installed the Blockit sound insulation mat and the behind the seat panels this weekend and I am very impressed. The mat just goes in the hatch area and the fit is excellent. I installed the two panels that go behind the seats behind the carpet. The carpet in that area is not tacked down so it is easy to do.
The mat looks very polished in the rear cargo area so I don't think that I will add an aftermarket cargo mat on top of it.
While commuting to work this morning on the freeway I really did notice a difference. I did not have to crank the radio way up and the voices and music were much clearer.
If you are looking for a real easy sound insulation solution I would recommend this product.
While at Carlisle last week, I came across a product called Block It at the TKO Performance display tent. We all know how many of our roads are not in the best condition and how load road noise can be. Block It is a multi layer foam pad which goes under the rear cargo mat. There are two additional pads which go behind the seats.
All I can say is the drive back to Florida was significantly better with Block It installed. It's not Cadillac quite, but the road noise it much less at highway speeds. Even at lower speeds while running exhaust in track mode, the exhaust sound was clearer and not as cluttered as before.
I got mine yesterday and installed it last night.
First drive to work this morning and I can tell you it makes a big difference. Those that say it doesn't must have some really frickn' loud exhausts.
It took the resonance away that the road puts through the rear hatch area (hatch floor, plastic) and the road noise from the tires is probably cut in half.
There's also a noticeable "quietness" inside the rear now that I never had before. I always had that "white noise" behind my head from all the noises coming from the rear hatch area. Now it sounds like the entire car is quieter.
It made such a difference I am no longer worried about putting dynamat or peel and seal in my car. I will however still do the peel and seal on the floor boards under the car because now that the rear is so much quiter I hear road noise from under the car... lol.
Overall, it's a great buy and I'm glad I bought mine!!
To start with, I am not a vender and do not sell these things, but WOW! What a difference. I have an 05 vert with borla stingers and love the sound. But on the interstate and highway speeds, the car is just kind of loud. Not just from the exhaust, but from road noise. So I bought the new "blockit' insolation kit sold here on the forum. Not the kind that requires you to remove the carpet or anything. Just put two pads behind the seats and one pad in you truck, or cargo area for a coupe. I drove my car at 70+ MPH for a good ways last night and WOW!!! Much smoother and peacefull sound. The stereo sounded better and the car just seems so much quieter in the cab area. I have had a C6 coupe and now have a C6 vert, and I promise you, this thing works! Just wanted to shout out a nice mod.
I was at Carlisle and the Blockit was sold out, so I bought the demo kit that was inside the Corvette parked under the TKO tent. In my opinion, it was worth it because it works. My C6 is very loud, as it is cammed, etc., with headers & NPP. It has an annoying low rpm drone. With muffler flaps open it is unbearable for cruising below 1,950 rpms. Even with flaps closed, the drone was very annoying below 1,950. Most of my cruising is between 1,700 and 1,950 rpms in 6th gear with 4.10 gears. With the blockit installed, the drone is gone at these rpms with flaps closed. Not just reduced, but gone. Below 1,700 drone is reduced to a bearable level.
With muffler flaps open the drone is reduced with the kit, but still louder than my comfort level. But it's a moot point now.
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Many thanks,
Dave
Just got my Blockit mats today and did a roadtest on the concrete I16 around Savannah and a couple miles on local black top.
Super easy install - drop in and forget it. I have a coupe.
Big rear mat had the slits for rings.
Put my Stingray logo rear carpet on top of the mat and also put the mats behind the seats.
I can tell a difference in noise ; can hear the radio better and believe a long cruise will be far more pleasant.
I have the Blockit mats. My wife can hear like you wouldn't believe. She is the perfect test for these. She stated to me that there was a significant difference in sound reduction. That's good enough for me. I thought there was a difference too, but I didn't want to rule out wishful thinking on my part so I had her listen before and after.
I put it in my 2016 Z06 last week and the difference is very noticeable. Less tire noise, radio volume setting is lower now and much more enjoyable. As another poster noted the exhaust sound now stands out more; my Z06 exhaust is normally set to track mode.
I did notice the action of the Bose audio pilot (auto volume compensation) is much more noticeable now and I turned it off.
obviously super simple to put install, in a 10 min trip to the store... noticeably quieter. i have LTH, high flow cats, and factory npp. to me it sounded like i had the flaps closed.. maybe even more quiet than that.
…… is it worth the $230?? to me yeah, because i am lazy don't want to pull all the carpet out.... so with that being said, money well spent to me
Finally put the top up. Certainly can tell the difference. Car is a bit quieter, you still hear the roar at take off from dead stops and when u hit the gas. But when cruising it's a nice peaceful quiet. But even more important to me, my c5 is a daily driver and living in Fl it gets really hot. I've noticed that my trunk is a lot cooler. Every night when I leave work I put my laptop bag in the trunk and I think hope the heat doesn't kill this thing. Well since the block it install the trunk with the top up or down seems much cooler. Well worth the price of admission lol.
…..Another thing I did was add the Blockit sound deadening mats to the rear hatch area. These things actually work well to attenuate the wind and road noise so that the exhaust sound comes through. I am surprised how well they work for this and it was unexpected.
My car is an 89 with the L98 engine, ….
Received mine today; installed and drove; it really does make a difference; Thanks for making a great product; I personally wish Corvette would offer a "sound deadening" option as I would buy it even if it was somewhat costly!!! This works great and easy to install!!, Dwight Alexander
I dropped in a set of Block It sound mats (cargo area plus one behind each seat) in my C7 Stingray coupe.
Using the Decibel X Pro app, I measured 2 - 5 dB lower noise levels on varying roads at varying speeds, which was noticeable, but more importantly, the cargo pad cut down the reverberations from the drum head that is the cargo floor and reduced the noise spikes generated by road joints and seams... The 'Vette is now about as quiet as my '11 Mustang GT 5.0, my previous "touring" car...
The pads aren't cheap, and do add weight, but they attenuate much of the most annoying noise from the back of the car. IMO worth the money.
I received my Blockit kit last week and today I received it’s companion Lloyd’s cargo mat today. Everything fits and looks perfect. Best of all, I can really tell a noticeable improvement in road noise inside the cabin. I never measured the db’s before and after the install, but it certainly is quieter and more comfortable.
Originally Posted by Redcruzer, post: 2342987, member: 16750
I received my Block it this week and was able to test it pretty throughly today. My EB convertible has a Ford Performance tune which eliminates the fake engine noise which is great but it also removed the noise canceling feature which introduced quite a bit of road noise in the cabin when the top was up and windows closed.
I ran sixty miles today with the top up just to test it and was pleasantly surprised how effective the block it is. Road noise was significantly reduced and made the car very pleasant inside. Honestly I felt all along that the road noise was coming from the rear seat side panel area that houses the top mechanism.. Looks like I was wrong.
What really has surprised me is that the Block it has made a noticeable difference with the top down. I would never have expected this. Sometimes in heavy traffic the noise can leave me a bit frazzled after awhile. After fourty miles at freeway speeds top and windows down I didn’t have that noise fatigue I would normally have in heavy traffic. More time may be needed to test this for sure. Fit was near perfect. Only draw back might be that it’s fairly heavy. Maybe fifteen, twenty pounds?
I wasn’t expecting too much from this product but it has exceeded my expectations and I would buy it again.
I just finished testing the tko performance sound deadner kit.
The kit consists of a sound deadening mat and two rectangles of sound deadening material that are placed behind the seat backs. (For more info see www.tkoperformance.com )
First impressions:
The mat and seat back pieces are well made (the cut edges are very regular and even. The pieces are symmetrical ( I measured ) and look good. The fit of the mat in the cargo area of my c4 is excellent. The installation was very easy.
First test drive:
The first test drive can be summarized as: Amazing! I expected some improvement, but the I was amazed at how much. The exhaust resonance heard in the cockpit is very reduced and the tire/ pavement noise is also very reduced. I drove on several road surfaces including newly resurfaced, old pavement and concrete. The noise level in the cockpit was very reduced in every case. The high frequency noise on the concrete roadway was from the front tire area only.
A very good product and I can highly reccomend it.
First impressions:
First test drive:
I noticed a remarkable reduction in noise with my trip yesterday down to our house by the beach... loaded with travel bags, my guitar in its case, and coolers (with beer), what a difference in sound, could really hear the music so much easier... maybe I'll drive like that all the time!
The BlockIt set for my C5 convertible arrived on Saturday. Installation for the trunk section took just seconds. With the Lloyds mat on top one would never know the BlockIt is there. The pieces for behind the seats took a bit longer because I installed them under the carpeting rather than on top of the carpeting. We took a 100-mile cruise and are very impressed with the improvement in the sound level of the cabin. Great product, great value, highly recommended!
-John
-John
[QUOTE=bigsapper;1599796402]My kit arrived yesterday. Took me 5.87 seconds to install; took longer to unpack, lol. Fits perfect.
Brilliant product! Makes a very noticeable difference. And I love the fact that it just takes a few seconds to pull it out when I go racing. And there's a no kidding health benefit; my tinnitus thanks you!
My wallet thanks you too as I can quit looking for a quieter exhaust system.
Highly recommended!
Highly recommended!
Originally Posted by Enzo, post: 2661716, member: 19985
I received mine two weeks ago and have been meaning to leave a response on here.
This definitely helped out a lot. I have the stock active exhaust on my 18, but with a X pipe installed. Track mode you can hear a lot of the drone coming. After installing this piece it has helped quiet it down a lot and enjoy the exhaust with windows down but no drone! One other thing I noticed is that this piece absorbs a lot of vibrations that come from the rear as well. It makes the car much more enjoyable on long trips. I drive one hour each way for work, thanks to good ole Orlando traffic and this definitely helped make that more enjoyable.
Great product! If you are thinking about getting one, just pull the trigger and you won't regret it!
IMO the BlockIt mats are a good bang for the buck and easy mod to reduce annoying road noise...
I added both behind the seats and cargo mats. The cargo mat seemed to be the most helpful as the cargo compartment floor is essentially a drum head transmitting noise from the rear end upward to the rear window and reflecting it forward to the seats. In some non scientific "tests" using DecibelX Pro app on my iPhone showed a 3+ dB reduction in overall sound level driving the same sample routes
Installed mat and 2 pieces behind seats in my 2018 GS last weekend. Drove 180 miles thru Texas Hill Country on a variety of roads, asphalt old and new, concrete and I am very impressed with the noise being reduced by 1/2 according to my ears. I can notice the difference and the music is "clearer" at high speeds..
________________________________________ ___
Click Here!
Combo kit sold separately costs $299.90
Click Here!
Any Questions, feel free to call us! 1800 778 9898
__________________
Serving The Corvette Forum For 23 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
Thank you for you orders. Please check your emails for tracking.
A few left in stock. Thank you very much!!
Tim
Tim
Back in stock. Back orders are also shipping. We have a few left.
Thank you for your patients!!
Tim
Tim
Thank you for the orders. We are getting these out ASAP. Check you emails for tracking. We have a few left in stock
Feel free to contact us if you have any questions .
Thank you!!!
Thank you!!!
do you make a kit that goes under the rear hatch carpet? thanks...c6...
For the C6 you can also place the 2 smaller mats that come with the kit under the carpet behind the seats (against the wall).
Thank you all, for the orders! Looks like we are shipping till Wednesday! Then we will close to enjoy the holidays!
From all of us here at TKO, to all of you and your families, Happy Holidays & Merry Christmas. Be safe out there.
We got blown out over the holidays. We have a few left in stock ready to ship. Make sure you use the code for your discount. .
Thank you all so much for your business. Here's to a happy and a healthy 2021!!
Happy 2021!!
All Blockit® orders placed during the holidays and this past weekend will start shipping tomorrow. Please look for an email with tracking!
Here's to an amazing new year!
God Bless!
God Bless!
We have a bunch of orders shipping tomorrow. look for your email with your tracking info. Any questions just reach out to us!
