Sharp light Innovations needs C6 to test new LED DRL system
Supporting Vendor
Looking for a C6 corvette owner willing to test the following setup:
I'm developing a new LED DRL system for the C6 that replaces the big blocky fog lights with an LED DRL bar. The LEDs will interface with the turn signal with a variation of our White DRL harness so the function will be completely automatic and completely plug and play.
These lights are dual purpose with an excellent pattern for both so fog light function will be retained. In DRL mode, when a turn signal is activated, the signaling side light will shut off until the turn signal is turned off. When fog lights are activated, the light will remain lit when the signal is on.
The tester will need to be local within 50 miles of Hockley Tx.
If you're interested, please email: president@sharplightinnovations.com
DarkAngelnl (02-12-2020)
Supporting Vendor
Hmm, I could sell you just the LED turn signal bulb (converts the turn signal bulb to high powered Cree LED) / harness setup. Would you be willing to take and share pictures of the installation and final product?
I literally just installed the Black LED ones last night. I love them compared to the projectors. The Projectors are 5500 and the Bars are 6500. I'm surprised how bright the bar style is. I'll also say the install isnt as easy as the sites say it is. And the brackets need fabrication to fit flush.
