Let's talk wheel spacers
#81
I have the same size wheels, and believe me, if you hit a pothole, you have bigger issues than the inner fender rubbing. More like a bent wheel.
#82
^^^^ My rear brake ducts have a ton of chips on em. Could be from me 'turning into the stones' I suppose. Meaning, kick the stones up and turning in hard makes the car hit em before they're past the rear. Idk. I can't help but think moving the tire outboard more would exaggerate that effect.
Not looking to put em on my car, just thinking aloud.
PS. I'm pretty sure my car has the same splash guards (unless yours are aftermarket).
#84
#85
I searched the thread for your posts but I did not see anything mentioning splash guards. Where did you get them and how much were they? Those I would install even without wheel spacers.
#86
Some people have a hard time with perspective digitally so I took a quick snap shot from the top down to show flush-ness with the outer lip of the tire to the fender. As you can see in the photo I tried to align the camera with the molding on the hatch area to keep it straight(ish).
Hope this helps anyone looking into spacers. As I stated before, next time I go to track the car (Probably April 2020) I will take some photos.
#88
^^^ Nice! And this is with stock GMZ06 wheels and a 20mm bolt-in spacers on all fours, correct? Did you have to grind/cut the wheel studs to clear the wheels mounting surface?
#89
It does look a lot more pronounced when you take the picture from the side. Looking down on it like that shows there is clearly a illusion. Although the fender does turn in at the bottom so there would be exposure to some degree.
#90
I have aftermarket ARP studs, so no. But if you have stock studs, you will have to grind/cut the non-threaded portion of the studs off to clear.
#91
I suppose there would be exposure to the... Mud guard(s)? I have ZR1 side skirts so both sides have a guard against any rock or debris flinging.
#94
#96
So I think the spacers look great and I plan to put them on soon. All the spacer naysayers are speculating about problems. Not one person has posted a problem after actually putting them on. So based on that I think there might be a small load change on the bearing but it’s negligible.
#97
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
I don't need spacers on my GS, but I think 1/2" or less spacers would not present a problem .... The real problem is when someone (ie "Ricers") install spacers that stick there wheels way way outside the wheel wells ... that wrecks the wheel bearings and throws the whole suspension out of wack.
Look at this **** .......
This guy also has so much negative camber dialed in that he has already ruined his suspension
#98
Here, members just want that close to flush look with their vettes that’s all. I think it looks great,IMO.
#99
I went to Harbor Freight to get a new jack that was on sale. Took the Vette. When I got back in the garage, I saw a piece of dirt on my hood. Here it was a small stone, obviously thrown up by the tires when I pulled in the driveway. Now, my drive is all paved so it's not like I'm out jumping stone fences or anything. This with stock width wheels, original equipment tires as shipped, and stock backspacing. Still, a stone was thrown up enough for me to drive under it and it hit the car.
Not a big deal, but this is what I was talking about earlier.
#100
on another note... anyone got pics of a 1/4 spacer on a base. im trying to figure out if that pushes the wheels past the fender.
Id like to get z06 calipers in the future. I just love the way the caliper looks over the base calipers.
