C6 Clock/Nav fix...
#221
Had trouble with burned CDs - Now Good!
I finally had success when using the "ISO" file from "TheCorvetteMechanic.com".
I'm experienced with computing, but none of my 4 CD burns worked in my 2007 C6 Coupe. After searching, I found that TheCorvetteMechanic had the fix in an "ISO" file. An iso file will burn the CD to its own parameters, rather than us trying to set our own burn specifications. My Nero burn specs created discs that the Nav system didn't like. After getting the ISO file, I right clicked it and selected "burn to disk". Thankfully, the Nav system ran it and fixed the "no clock" problem.
For anyone having trouble with discs not running, this will likely work for you.
#222
I do not have a way to burn a disc. I will gladly pay someone to do this for me. Please send me a PM and I will give you my address and send you payment. Thank you in advance.
#223
You guys are having much better luck than me. I downloaded the file and uncompressed it which resulted in a 10.8MB KWI file. I burned the file on to a CD-R and it did not work. I also burned the file to a DVD+R and still no clock? I also tried burning with NERO software and Microsoft. Any advice?
#224
have dicain send you his copy.
#225
Received 1,792 Likes
#226
A file is a file. I do not think that using a different computer will make a difference. I did load it in to the DVD slot and all it tells me is that it is not a map disc. I also made other disks using NERO and Windows but neither worked. I made another this morning and it is a CR-R 74. I can mount it and see that the KWI file is on it. Will try again today. Luckily, I do wear a wrist watch!
#227
Having Trouble? Try This!
Download the "ISO" file from here:
https://www.thecorvettemechanic.com/...ighlight=clock
This will format your CD differently from the other "fix" file. That difference worked for me.
All you do is locate the "iso" file and right click or drag to the burner to install on the CD-R already in your burner.
A CD/DVD burner is $20 on Amazon. If you don't have one, take the above info to someone who does, like the neighbor's kids. 5 min an you'll have a CD.
lwise4 (05-29-2020)
#228
#230
Thank You Thank You After making 3 other Disk's, this one did the trick! I don't know why the others did not work and I do not care now that this is the fix!
#232
Just did this, with the help of my wife on the computer, and it worked like a charm. I now have my clock back, plus, the nav works. Thanks Corvette Forum.
Happy Fathers Day to me!
#234
Re: Clock disk
Just a FYI, I disconnected my battery to do the paddle shifter mod and the clock was still displayed when I hooked the battery back up.Looks like it's a one time software fix.
74Plb
74Plb
06Rawpower (08-16-2020)
#235
Fix worked as advertised and like a champ. Seven-year old battery gave out Saturday. After replacing the battery there was no clock display. Same deal as others. Thanks to the trailblazers who provided documentation and others their experiences, the clock display is back. You just can't beat this forum. NTHALP
#238
worked perfectly for me on first try using the May iso release. Burned to Memorex CD-R on Windows 10, the car liked it fine. I was clockless for almost 4 hours lol
I just got done installing a Z51 oil cooler and swapped my battery with an Optima Red Top, I'd say now we're cooking but hopefully I won't see 300F oil temps at the track anymore.
#240
Received 1,095 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I've been sitting on the sidelines, rather smugly I'll admit, as my clock has worked perfectly. Last night I looked over. No clock! Oh well, looks like time to burn a disc!!
Update: Done! That was easy!!!
