Travelling with 2 fobs...
I use the passive door lock, (doors lock when leaving car) and it works great.
When travelling across country, I carry both fobs on my person.
Did you know?
With both fobs, the auto (passive) door lock will not work.
Glad I found this out, because when I stop for gas, the doors were not locking.
So now when I travel, I turn off the passive, and use the manual lock on the fob.
...jerry
Did you know?
...jerry
rc51racer (10-17-2019)
Race Car Tech
That's good to know for sure. I also have passive locking, so when we travel, I always keep FOB #1 on my person, and the 2nd FOB is kept in my wife's purse. There's a better than good chance that one of us will have a key FOB on us. The spare FOB is kept in a Faraday Key Fob Bag, which prevents radio signals from reaching the FOB, or for it to transmit.
I also keep a spare key in my wallet. there is no way that both of us would leave the vehicle without either a wallet, or a purse.
We have it well covered.
Received 1,798 Likes
Did you know?
...jerry
Did you know?
...jerry
There is no reason for autolock to not work just because there are 2 FOBs. When the last door closes a timer starts. 10 seconds later the car checks to see if it can find a FOB inside the car. If it can it beeps the horn to tell you that you forgot to remove a FOB. If it can't because the FOB is too far away from the antennas to be found, the doors will lock. The car does not count the number of FOBs entering or leaving. It only looks for a FOB when the computer tells it to look for a FOB. Using the manual button on a FOB to lock the doors would make no difference except to shorten the timer for when to look for a FOB inside.
So if you have both FOBs with you, how did you determine that the doors were not locking? The locking/unlocking sequence is rather complicated and non-intuitive so many if not most people think the locking/unlocking is determined by the proximity of the FOB to the car which it is not.
I have done many tests, by walking away with 2 fobs, then leaving them in the house coming back and
doors were unlocked.
Repeating with 1 fob and find it's locked.
Just tried it now with fobs 1 and 2 in my pocket. When I got out of the car, and closed the door, it autolocked about 10 sec later. Left the fobs in the house, went back to check, and it's still locked. All I can say is that autolocking works with 2 fobs in and out of the car on my '11.
That's interesting, I should have mentioned mine is a 09 coupe.
I don't have the "fob left in car" warning turned on.
Maybe that's got something to do with it??
Received 1,136 Likes
Did you know?
...jerry
Did you know?
...jerry
Triumph Jerry (10-18-2019)
Yah, I was REALLY shocked, after stopping at several gas stations with laptop on front seat
and many valuables in the car.
That it wasn't locking.
Thought I better put this in the forum.
Now that I know some DO work with 2 ...I will find out why.
I will turn ON the fob left in car warning and try it.
How do you know which fob is the primary?
Race Car Tech
Normally it is fob marked #1 that has been programmed to be the primary initially. It is also possible to reprogram any FOB to be the primary FOB.
The vehicle comes standard with two transmitters, and up to four can be matched to your vehicle. The owners manual explains how to program the FOB's.
I'd just not bring both fobs. Seems like the easy solution here.
Each fob has its' own bundle of pre-sets, including Auto-Lock.
Do you have Auto-Lock turned on for both fobs?
If not what's probably happening is that when you unlock/open the door, the car is recognizing the fob (closest to the antenna) that may not have Auto-Lock programmed for it.
I have 2 different DIC greetings so I know which fob has been recognized.
It's not about exiting the car, it's about what happens when you approach/enter.
My best guess for your issue, anyway..........
The following 2 users liked this post by Knob Jockey:
FortMorganAl (10-18-2019),
Seller told me to get second fob from dealership and he paid for it.
Dealership programmed second fob.
If not what's probably happening is that when you unlock/open the door, the car is recognizing the fob (closest to the antenna) that may not have Auto-Lock programmed for it.....
