August Special on Lowest Sitting Sliding Seat!
Former Vendor
We have a special running thru August on our ST3 seat with choice of mounting hardware. When used with our ultra low brackets with sliders it gains 2"-3". It also is designed to use the stock seat belts INSIDE the seat, where they actually can tighten. As a note, our ultra low brackets on the website now offer a version with integrated lap belt mounts, but you could not use that bracket and get the seat to sit as low as possible. The integrated tabs would interfere with spreading our sliders far enough apart for the seat to drop between the sliders. The sliders will come with adjustable locations for the stock seat belt but if you need the seat to sit this low and still want to mount a harness, I will discount the rear harness mount we offer as well. Just mark@marradind.com before ordering. If you don't need the seat to slide I can provide the aIuminum rails for installation.
If you need other options shown on the ST3 product page, I can create a custom order link. mark@marradind.com your desired setup and we'll discuss.
The pictures below show how low the ST3 sits with our sliders. The new ST3 now has ribs in the back for extra stiffness, but still sits as low.
Below is the link to the August Special.
http://www.marradind.com/proddetail.asp?prod=8-19-ST3
More info on the ST3 seat and options are below.
http://www.marradind.com/proddetail.asp?prod=ST3
Delivery in 4-6 weeks.
Mark
Mark
Former Vendor
