2013 60 Anniv Splitter clearance
Hello fellow Corvette lovers. Does anyone know the distance from the bottom of the C6 front splitter to the ground? Mine is off right now and being repaired and I am having a new garage built and driveway installed and I want to make sure I have enough clearance to put it back on with the new driveway, The driveway installer said the only way he can guarantee it is if he knows the spec. Please help if you can. Thanks!!
if you are talking about the front air dam which is the lowest part of the front mine is two and a half inches off the ground.
Pro Mechanic
Received 3,988 Likes
The splitter on my 427 is 3 3/4" to 4" from the ground, car is at stock height, not lowered. The air dam underneath the vehicle is actually lower that the front edge or bottom of the splitter.
