Cigarette lighter....
Old 05-30-2019, 01:01 AM
Todd-O
Todd-O's Avatar
Default Cigarette lighter....
Hey guys,
Bought a tire inflator for a tire that got a screw in it. Used it one day and it worked fine.
Tried it 4 days later and it didnt work. Took it back and got another, same thing. Got a 3rd one, same thing.
Is it an easy fix or a PITA? Is this common for this to go on the fritz? i dont smoke so i dont care. But, id like to use the port if I get another screw or nail and im on the side of the road.
Thanks!
Old 05-30-2019, 01:34 AM
Gator6977
Gator6977's Avatar
2018 C6 of Year Finalist
Start with a check of the fuse. Not uncommon to blow one. If it's the actual cylinder/lighter/portion you plug into, they're really easy to replace. One hot wire on the bottom, with the ground on the side. Hardest part would be removing it from its housing, which would take a total of 3 minutes to figure out.
Old 05-30-2019, 01:59 AM
Todd-O
Todd-O's Avatar
Got it. Thanks. Will this be on the passenger side foot area where the fuse was for my NPP exhaust?
Old 05-30-2019, 04:33 AM
Gator6977
Gator6977's Avatar
That's where she's located. Labeled LTR, see below...
The following 2 users liked this post by Gator6977:
chrisharek (05-30-2019), Fletch F. Fletch (05-30-2019)
Old 05-30-2019, 04:51 AM
Todd-O
Todd-O's Avatar
Beautiful! Thank you.
Old 05-30-2019, 09:35 AM
SouthBaySurfer
SouthBaySurfer's Avatar
Your car should also have a 12v PowerPoint in the center console.
Old 05-30-2019, 10:34 AM
dr_gallup
dr_gallup's Avatar
Yeah, I blew the cigarette lighter fuse with my compressor the second time I used it too. There is a high in rush current when an electric motor starts, evidently enough to blow the fuse after a couple starts. A smaller compressor may never do it.
Old 05-30-2019, 10:47 AM
madsonp
Support Corvetteforum!
madsonp's Avatar
Received 1,776 Likes on 1,180 Posts
You may be tempted to replace the fuse with a higher amp rated one, but as we all know, that's not a good idea. I'd suggest getting an adapter, and come directly off the battery such as this. https://www.ebay.com/itm/1pc-Car-Bat...YAAOSwMgdXzBud
Old 05-30-2019, 10:56 AM
Landru
Landru's Avatar
Received 1,052 Likes on 825 Posts
I'd actually bought extra fuses, happened that often.
Stopped using car's 12V, bought a 120VAC compressor.
Worked fine but hated dragging a cord around, ultimately bought a digital handheld inflator from Sharper Image.
Small powerful lightweight NiCad battery charges fast & good for 8 tires. Like $50. Well spent, IMO.
I've had enough of that damned fuse.
Old 05-30-2019, 01:06 PM
Old Ben
Old Ben's Avatar
2017 C6 of Year Finalist
I've always used the receptor in the center glove box with no problem.
Old 05-30-2019, 02:00 PM
Todd-O
Todd-O's Avatar
Ok. Thanks guys. Ill look for the port in the glove box. Also like the idea of the hand held unit from sharper image...
Thanks!
Old 05-30-2019, 02:40 PM
ruenvs
ruenvs's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-‘19-'20
OP states that 3 different inflators stopped working after one use. No mention of changing fuse between uses. Sounds like POS inflators tome.
Old 05-30-2019, 02:45 PM
Todd-O
Todd-O's Avatar
That is correct. I did not replace fuses between units.
Old 05-30-2019, 04:20 PM
Iceaxe
Iceaxe's Avatar
Received 2,610 Likes on 1,395 Posts
More high quality Chinese craftsmanship I'm guessing.
Old 05-31-2019, 08:29 AM
irok
irok's Avatar
As far as I know the center console 12 volt plug is fused higher and will not blow when you plug your compressor into it.My compressor blows the lighter fuse but never an issue with the console plug
Old 05-31-2019, 09:31 AM
Kenny94945
Kenny94945's Avatar
See post 10.
Using the cigar lighter, under the AC module on the dash, will consistently blow the fuse under the passenger side foot well in the fuse box located there.
The cover to that fuse box can be frustrating to remove and reinstall.
This fuse "popping" is a known issue if the cigar lighter is used for accessories.
The "cure" is to use the, in center console under the console lid, accessory port for your tire inflator as mentioned in post 10.
Good luck.
Old 05-31-2019, 02:57 PM
Todd-O
Todd-O's Avatar
Understood. Thanks for the help guys....
To Cigarette lighter....
Quick Reply: Cigarette lighter....
