TPMS not resetting...
Hello,
Trying to reset my TPMS. Car is in accessory mode, but will not beep when I use the radio frequency tool. I tried letting air out of the tire, too.
What am I doing wrong?
Car is 2010. Is it possible they put the wrong TPMS sensors in??
This might be a silly question but are you holding down both the lock and unlock buttons on your fob after putting it in accessory position. You should then get a horn beep to acknowledge that you are in the TPMS learn mode.
The you could possibly have sensors that aren't suitable. I've read claims that some of the cloned sensors can be problematic and that it's best to use OEM sensors I replaced my 10 year old ones in spring of 2017 and using the OEM Schrader sensors everything worked perfectly with the TPMS learn procedure.
Be sure that the battery in your tool is fresh, and that you are actually positioning the tool correctly against the tire (not the wheel). If the tool is OK, then replacing the TPM sensors with the ones I suggest may be your simplest and cheapest solution. Any tire shop capable of mounting Corvette tires can replace them in very short order.
If you PM me I can point you to a non-CF vendor who sells C6-compatible TPM sensors for about $110 for a set of four in chrome (add $20 for black), plus very modest shipping.
But the whole idea of this package was to be convenient... Wheels, tires, and TPMS all in one. Should work.... Reputable vendor... Idk what's going on here.
Received 8,874 Likes
I bought my wheels/tires/TPMS mounted & balanced as a set for convenience as well. Unfortunately had the same problem you’re having (plus tires not balanced properly ). That turned into 4 months of inconvenience trying to get the tires balanced correctly, 2 new wheels shipped to me & both front tires replaced. The TPMS that came in the package gave me nothing but issues so I replaced them with OEM & had the vendor refund me the cost of OEM TPMS.
No problems since & you can get the OEM sensors on amazon for $32 ea.
Received 1,636 Likes
Contact them, i’m sure they (Keith) will try and help. Unfortunately things like this sometimes happen. Most of the wheel vendors seem to have a good reputation around here. Probably a bad TPMS that will need to be replaced.
Update
I went to Discount Tire, and their tool picksed up the sensors. However, it is identifying them as 2005-2009 sensors, and advises that the sensors are "improper" (or something to that effect).
$300 later, the wheels and tires came off, and the proper sensors were put on. I think FSS (vendor) should.refund me for their tire sensors, and also pay for the new ones.
Also, discount tire used this kind of lift... Never seen this before! Ok to use?
Did you contact FSS and give them a shot at correcting their error before you spent $300.00 at Discount Tire?
Sent you a PM, and if they put pucks under there when using that quick jack you should be ok, if they didn't I'd check for damage.
Also FSS will ask for the TPMS back, so hopefully DT didn't snap them off like they did mine. They gave me a bag of broken TPMS back & I told FSS they could take it up with DT.
I called today and no answer....perhaps closed? Hours aren't listed.
Even if they sent me the correct sensors, the tires would have to come off, and I do not live near them; it would have to be done at another facility, regardless. $300 is roughly the cost of the sensors and labor at a any major chain (I quoted at two).
Time and frustration as well... This was supposed to be a convenience deal - wheels, tires, and TPMS ready to rock and roll for my DIY install. Now I've sunk 8 hours into figuring this out, spent money on tools to do the job myself, and now an additional $300 to have it done by a tire shop (which was what I wanted to avoid in the first place).
So, no, simply "making good on the error" by sending me the correct sensors is not enough - not even close.
$300 is a bit much, new OEM sensors would have been $120 & install should have run you about $60-80. Each DT location does seem to make up their own pricing though. I have 4 within 20 mi radius & they all gave me different quotes for install of the TPMS from $60 - $250. I asked the guy at the $60 location why the discrepancy & told me it shouldn't be as they are just supposed to type it into the computer & the price pops up, but that they have ways to manipulate what they type in to get different prices. Pretty shady if you ask me.
