C6 aftermarket radio
Does anyone know what harness I need to add a aftermarket double din radio. I have a base 2007 with does not have Bose. Homely not even sure I have onstar...
Received 1,636 Likes
I never used this one but another option to the Pac is the Crux SOCGM-17C. Make sure you also pick up a GM antenna adapter if you go with the Crux. The Pac RP5 comes with one in the package. Also if you get your head unit form Crutchfield, they offer the harness and other installation gear in a discounted package. The CRUX package is $25 with a head unit while the PAC is $80 and both packages come with the bezel and the antenna adapter, which is already included with the PAC, is also added to the CRUX package.
I dunno if I would let the install techs from Best Buy in my car. But then again I do all my own work, so it all depends on how comfortable you are with installing things. Radio is easy, since you can wire up the harness in your kitchen and just plug it in after and bolt it all up.
