TPMS showed 0 psi on all 4 tires
(BTW, I did a quick search on TPMS and couldn't find anything on this particular issue, although I doubt I am the first to experience this)
Started the car up this morning, and all the indicators seemed to be displaying correct info except the tire pressure which displayed 0 (zero, not XX) for all 4 tires.
After a few minutes... very few... maybe 2 or 3 minutes of driving, they started showing the presumably correct tire pressure, 29,30 front, 30,30 rear.
Is car trying to tell me something?
PRNDL (02-04-2019)
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
If you had the car's battery disconnected prior to the TPMS sensors reading 'zero' pressure, it takes more than a few miles before they will read correctly ... don't happen right away.
If they continue to read zero pressure, or read 'XX', then you you need to replace the TPMS sensors (dead TPMS sensor batteries)
These sensors normally only last for about 7 years or so.
PRNDL (02-04-2019)
