C6 Z06 Makes an Extra 100RWHP Easy
Old 09-24-2018, 09:03 AM
Late Model Racecraft
Supporting Vendor
Late Model Racecraft's Avatar
Default C6 Z06 Makes an Extra 100RWHP Easy
Here is a VERY clean 2008 C6 Z06 we just finished installing a custom grind camshaft in! She picked up an easy 100 RWHP! It is amazing how much power you can pick up in these with such little modification!
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Old 09-24-2018, 12:29 PM
BadgeZ28
BadgeZ28's Avatar
Steve, how much more do you see from a cam swap on a Corvette LS3?
Old 09-25-2018, 01:04 AM
Dano523
Dano523's Avatar
Received 3,028 Likes on 2,182 Posts
Please show Dyno chart of both oem cam and your cam, but to full 7K pulls for both; since the LS7 pulls all the way to 7k before the rev limiter kicks in.
The problem on the LS7 in the C6 has always been that motor runs out of air and starts chocking for more air about 6.3K since there is not the needed room under the hood for the needed size intake manifold to begin with.
Hence you can add more lift and change duration on the cam to pull more air in below the 6.3 mark to make more power down lower, but all this does is cause the motor to start starving for air before the 6.3K mark isntead. In the video dyno graph you show, the motor is already going flat/starving for air around the 5.8K mark/HP going flat from there with the new cam instead.
Simply put, stock LS7 problem is not cam, but being able to breath above 6.3K, and why with even a supercharger on the car only putting out 6lbs of boost to just allow it to breath correctly all the way to 7k, the LS7 will put out 650HP on stock cam and exhaust with a ruler straight line of HP increase from idle to 7k instead..
Old 09-25-2018, 08:09 AM
BLEKVET
BLEKVET's Avatar
Ummmm. Man, great power from a cam! Love the LS engines. Thanks LMR for the post.
Old 09-27-2018, 05:39 PM
Supporting Vendor
We are glad you love it!
Old 09-28-2018, 09:17 PM
HouseS2k
HouseS2k's Avatar
You ever been flat out ignored.....
Old 10-01-2018, 05:43 PM
jayyyw
jayyyw's Avatar
Old 10-03-2018, 01:47 PM
Shaolin Crane
Shaolin Crane's Avatar
Every time I text a woman
To C6 Z06 Makes an Extra 100RWHP Easy
Quick Reply: C6 Z06 Makes an Extra 100RWHP Easy
