New torque tube and clutch, repairs
Don't you just hate when you're going on a 2 hour drive and the car starts making noise 1km from your destination? Well I limped to destination anyway since the car was still moving and the engine still sounded nice. The awful mechanical noise only happened when I engaged the clutch. I thought to myself it's either a clutch, thrust bearing or transmission issue. I hope it's not a transmission, I don't want to spend 6k on parts alone!
Well, the dealership I brought it to has loaned me a Cadillac XT5, which is very nice of them. I don't like the vehicle even though it is a very nice vehicle. It's too plush and luxurious for me.
Anyway, back to the Corvette. Turns out it's the torque tube. Upon inspection, there was a bolt or something that really went to town in there and so they recommended I get a whole new torque tube assembly from GM instead of having it rebuilt (rebuild was the original plan). I asked for a new clutch while they are in there. And since my transmission seems wet, but no drip, I asked that they check the levels and let me know in that too.
I don't have the final repair bill yet, and they mentioned that because I have a complete aftermarket exhaust, it adds to labor costs (I don't see why, but whatever), the estimate is at around 5000$ taxes in. so about 3k$ in parts, 1500$ labor + taxes. Seems reasonable to me, although expensive, this is Canada...
Anything I should ask them to do while they are in there? I'm open to suggestions.
I wonder if your dealership actually has access to a new torque tube. GM stopped making them a long time ago, and even then new ones were hideously expensive. I had to have my torque tube rebuilt a couple of months ago. It was vibrating something awful in a way I've never felt before. The rebuild required three new bearings (one at the front and two at the rear) and two new elastomers ("guibos" - modern U-joints). Like the torque tube itself, the bearings and elastomers are out of production, and I was very lucky to find them. While the torque tube was out, I had the torque converter replaced with one more suited to the E-Force supercharger's 600hp. I had the A6 completely rebuilt with new heavy-duty clutches and solenoids. And for good measure, I swapped out the 2:56 rear end with a used (but much newer) 2:73. Lather, rinse, and apply Chuck/CoW's A6 tranny tune. The result is an '07 vert with 135,000 miles that drives like new again.
Chuck CoW (09-19-2018)
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thank you Doc!
Certainly drives a LOT better now!
Chuck CoW
