Morimoto C7-Style XB-2 LED Headlights
#301
I don't know if he's necessarily gouging people. People are asking for him to build the harness, actually begging him. At this point, the harness is more of a convenience than anything. The lights work 'as advertised' as long as you flick the switch on the stalk. That's all people are complaining about. If you want the luxury of not having to hit one switch then I think it should cost you, and right now the cost is $250. Isn't capitalism great!!!
#302
Originally Posted by Frankie15
Eh, to be fair it also disables the "L" shaped light when turn signals are applied and allows flash to pass to work when your headlights are off. It's more than just paying $250 to "flick the switch for you". There's nothing you can do manually to match that functionality (without a harness or modification to the headlights of course).
I read everything on the Morimoto site before I ordered. They never promised that the units would be identical to the C7 in functionality. In fact, I think folks on here injected their own version of reality into their reasoning for ordering based on the excitement and based on the cheerleading that was going on by the vendors. The phrase 'plug and play' was repeated over and over again, and was included in the Morimoto description, so it's not too far fetched for buyers to make the leap and think that that meant their units would work identical to the C7, and there were a few here that did specifically ask about the C7 functionality and they were repeatedly assured that it would be just like it.
From that perspective I guess some are right to feel a little misled and perhaps the vendors should consider some sort of way to meet in the middle. If Morimoto makes some sort of factory fix then maybe they should provide that at no cost, or minimal cost, to those who already purchased. However, until something like that happens, the vendor who took it upon himself to custom build the harness that fixes everything is more than justified in charging $250.
Personally, I'm happy with the product as is. I don't even care that I have to flick anything (I was already flicking the fogs on at start to dim the amber DRLs) and that the L doesn't completely go out with the turn signal. If the harness drops in price then maybe.
#303
#304
That's right! So it actually is a modification. Well then even more reason to justify the $250, to some extent.
#305
Supporting Vendor
Just a quick update, the headlight manufacturer is indeed investigating a harness of their own. I don't anticipate the cost to be anywhere near $250 but cannot confirm anything as of right now. Will advise more regarding this as soon as I know it.
__________________
Cole Manzelli
Cole@Vette-Lights.com
(405) 209-5328
Vette-Lights.com
"FORUM10" - 10% Off Almost All Upgrades
___________
C5 Collection
C6 Collection
C7 Collection
Cole Manzelli
(405) 209-5328
Vette-Lights.com
___________
C5 Collection
C6 Collection
C7 Collection
#306
I work in tech, when buying brand new tech, you are going to be by definition an "earlier adapter", and you have to expect these types of things.
#308
Supporting Vendor
Originally Posted by Vette79C3
Is there a trick to getting no gap after installing these headlights? I can't seem to get them center let alone without gap
#309
Supporting Vendor
Originally Posted by GS057
When are the taillights going to be available? Are they included in the current boat shipment ?
#313
Would adding this supplemental harness require removal and re-installation of the assemblies? I just invested in 4.7 standard labor hours at my dealership having the original pods removed and replaced with my new Morimotos. I would be very reluctant to repeat that no matter how cheap a new harness might be.
#314
I wouldn't think so. I just loosen the fender liner that meets the front bumper and you can see both the female an male connector of the harness there.
Eritosthenes (08-16-2018)
#315
Supporting Vendor
#316
Supporting Vendor
Hope everyone is having a great weekend!
#317
I did some fine tuning to get the cut off's to match. The passenger side I had to go buy some washers to make the headlight level with the driver. Originally the passenger side was lower and when I would adjust the height it would make the cut off on the right side seem brighter if you were standing in front of it. Minor thing but OCD kicked in and it bugged me so here's what it looks like as of now after some adjusting.
#318
Supporting Vendor
Preorder pricing is still going due to limited availability and slight lead times before shipping.
