Air noise inside cabin on fast acceleration?
I've been out of the corvette world for several years and am now test driving some cars and trying to find the right one to get back into.
Yesterday I drove what I thought was going to be a car I really liked. Very clean 2011 Grand Sport 4LT. And then while test driving it, I accelerated hard in it and suddenly got a VERY LOUD wind/air rushing noise INSIDE the cabin. It sounded like it was coming from the A pillar area near where the bluetooth fob (sorry dont know the real name for it) is. I repeated this a couple times, getting it to do the same thing. While decelerating, it almost sounded like whatever made that noise was closing up, and then it stopped. By the end of the test ride, it made the noise at even slower speeds. I've never heard anything like this before. The dealership tried to tell me because it was a windy day.... . Any ideas??
I would try finding another GS to test drive as a comparison.
Off the top of my head, if a catalytic converted was defective and the core was broken, one can hear the exhaust trying to escape and it will sound loud because of the restriction of flow. A muffler could do the same thing, but they are in the rear, and less common a problem.
LoneStarGirl (04-07-2018)
Another thought, maybe the roof panel was loose at one of the clamping levers, as this has been a forgotten item to check once the roof panel is re-installed. You'll hear about the flying roof club from time to time.
LoneStarGirl (04-08-2018)
Pro Mechanic
Received 3,988 Likes
there was a concern with a trim piece in the windshield / cowl area causing a noise while at speed on the C6 generation................ a search for "buzzing noise" may lead to the topics............ currently at work, and limited access otherwise I would be able to find them............
I would make sure the roof is latched properly, and make sure the latches are holding it tight when closed. You might also see if the roof panel is coming unglued, and check the A-pillar trim is tight.
Thanks everyone. Whatever it was, it definitely wasn't right! I'm starting to think I should save my pennies and go for a C7. It gets a little frustrating looking at C6's, seems so many have been used and abused. This car that I posted about was really a beauty but I just got a bad feeling from the dealer, and it had terrible orange peel paint on the back. I see that this is a common issue but, it was SUPER apparent and the sales guy acted like he couldn't even see it.
Pro Mechanic
even out of state, as long as you get a lot of pictures and information first, if you decide to go that route, as the ride home makes it all worthwhile...........
good luck in your search for the right one for you........
Keep looking, there are a lot of garage queens out there you just have to find the one that suits you. Expand your search and be diligent but don't lower your standards. The internet is your friend, good luck!
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Another possibility might have been a cold air intake (CAI)---some of those make a more pronounced sound of air intake and usually only on half or full acceleration. But, you are correct that at least paint-wise, the newest C7s have been painted in the new Paint portion of the plant with brand new equipment and orange peel is drastically reduced. This goes for cars painted from Nov., '17 onward. Just fyi. Good luck.
But it is also correct that there ARE a lot of garage queen C6s if you can find them. Depending on where you live (and I might guess TX, or from there), there should be many in your area or state.
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
Received 1,792 Likes
Sound really bounces around the cabin in these things, and I personally find it's pretty hard to figure out where noise is coming from. Also, you don't say whether or not it's a coupe or vert, but it it's a coupe, I have the identical car (maybe not the same color). When you stick your foot in it, there is a definite increase in sound volume when the engine hits 3500 RPM, and the NPP valves open the exhaust up. It's very noticeable, like an afterburner kicks in. It's not speed related, but engine RPM related. Maybe this is what you were hearing?
dealers warmly embrace the "I don't (hear/see/smell) it" syndrome on any used car. I don't like buying from dealers because they cannot tell you even one thing that you cannot find out for yourself.
To find the Corvette that really hits the sweet spot for you, you have to look and research lots of them.
Just because a car is new (C7) does not mean it won't have similar issues, or that the dealer will agree with you. Lots of evidence about that.
Another thought is possibly the windows need to be re-indexed. It they are not going up all the way the window might be sucking out at speed, that makes a huge wind noise. It can be tough to localize noises in any vehicle but especially in a vehicle you're not used to.
I don't care what you do to it, the road noise will be well beyond most any other car you would compare. It is built for performance which it certainly delivers and part of that performance is due to weight reduction,,,,,, such as insulation.
The C7 offers big performance and big value. It is more of a sports car than a luxury GT. If you want the C7 to be more of a luxury GT, noise reduction will take you a long way on that journey.
Disclaimer: I have done only minimal noise suppression on my current C7 and prior C6 because I was and am reluctant to add weight to what I consider to be an already reasonably quiet sports car. I have done some significant sound suppression work on my old ride, a 2010 370Z w/Sport Package, now that car had some serious road noise! Basically you need to gut the interior and cover every accessible surface with a DynaMat type product and cover that with one or more of the sound absorbing mat products. Then search the forum for the consensus choice for the quietest tires, put a sun shade on your acrylic roof and hopefully you’ll be happy.
Your concerns are legitimate but the reason you are getting some push back is because you are taking the car in a direction that it was never designed to go, you can do it and you will most likely have a really nice GT, maybe not luxury, car when you are done. Just recognize that maybe 90% of the people on this forum would consider selling a body part to knock a second off their ET so adding heavy sound reduction matting strikes some of them as sacrilege.
Received 1,136 Likes
the c7 offers big performance and big value. It is more of a sports car than a luxury gt. If you want the c7 to be more of a luxury gt, noise reduction will take you a long way on that journey.
Disclaimer: I have done only minimal noise suppression on my current c7 and prior c6 because i was and am reluctant to add weight to what i consider to be an already reasonably quiet sports car. I have done some significant sound suppression work on my old ride, a 2010 370z w/sport package, now that car had some serious road noise! Basically you need to gut the interior and cover every accessible surface with a dynamat type product and cover that with one or more of the sound absorbing mat products. Then search the forum for the consensus choice for the quietest tires, put a sun shade on your acrylic roof and hopefully you’ll be happy.
Your concerns are legitimate but the reason you are getting some push back is because you are taking the car in a direction that it was never designed to go, you can do it and you will most likely have a really nice gt, maybe not luxury, car when you are done. Just recognize that maybe 90% of the people on this forum would consider selling a body part to knock a second off their et so adding heavy sound reduction matting strikes some of them as sacrilege.
this thread is 15 months old.
