Dead Battery Again
OK: Now that could be my problem 'OnStar' because my vette battery will drop low enough only after a couple of days sometimes and will not kick over.I had a 5th battery installed 2 months ago and it was fully charged and read 12.6 volts when installed.(AC Delco 42 month).Every day i go out and check the battery voltage before start up and it will read between 11.7 to 11.9 but of course that's depends on how cold it it is..'Never under 40 degrees) for a few months down here....Like you said OnStar is trying to connect to my car,well my vette sits under a tin roof/carport witch will block the signal.I know because i get the icon on my navigation screen...Hum.Thanks for that infor.
Cherokee Nation (03-07-2018)
dead battery
check your negative cable connection. Clean and reseat it. Make sure that it's connected by the proper tapered nut (not a common flat nut).
Mine dies like that too due to poor connection from the negative cable. I am not sure why.
I discovered the previous owner stashed a 10mm wrench and battery terminal brush in the storage bin. Now I know why he did that. But I still don't understand why the negative terminal doesn't stay connected.
I'm sure everyone has different issues resulting battery life.
my initial one was the passenger seat adjuster was stuck.
it kept cycling and would drain the battery after one day.
once I figured it out, 1-1/2 years later, no problem.
but I also have an issue with the negative cable.
It has come loose twice while driving. go to start, nothing.
I can't get the terminal tight enough though. I can still work it loose by hand. for now, I get it as tight as I can, then twist it bit to help it seat better.
good luck!
good luck!
good luck!
cgladish (03-07-2018)
Hello all,
I'm looking for some insight. I replaced my battery about 2 months ago (2012 GS) with the OEM one from autozone. After not driving it for about 10 days, it's dead again. I finally got it started but I had to charge it for a about 30 minutes using my wifes car to get it to finally turn over. Then, after running it for a few minutes, I shut it off and turned it back on but wouldn't turn over again. Clearly my battery is pretty much toast.
Is there anything that I could be doing that would cause the battery to die? I don't want to have to buy a new one every 2-3 months. So if there is some secret that I'm missing I'd love to hear it.
Thanks for any thoughts!
Otherwise, if you have anything drawing too much current, best to disconnect the '-' battery terminal and connect a DVM in current mode to the terminal and the other lead to the cable. If there's more than a few milliamps of current draw, something may be drawing too much power. Just make certain no light is on with the hatch up. From then, it's going fuse to fuse to measure current draw until you find the circuit that's the power hog.
I didn't read the whole page but first things first. When you bought the new battery did you charge it completely? People think that new batteries are charged up but sometimes they aren't. I ALWAYS charge a new battery until my trickle charger says that it's fully charged.
2nd this. Alternators aren't like the old generators. They won't pick up (charge) a dead battery. You should charge it for several hours when you buy a new battery. Preferably overnight.
That's what I just did. I replaced the battery, then immediately connected the tender. When the tender showed a full charge, I started it and drove it for about 45 min. Hopefully, I broke in the new battery in the best possible way...
C6 of Year Finalist (stock) 2019
Simple answer, GM engineering. Never had a problem with any other car like a Vett. They even have a bulletin out on the vette and cadi 05-07 for a parasitic draw because they programed it wrong supposedly on the automatic door lock setting. Won't tell people, most of the dealers probably don't know the fix, and they won't reprogram free...they charge for their own admitted mistakes. Got to live with it if you want a vette, one thing or another. Some get lucky others don't. Some depend on how it's been taken care of and driven. Then they put that stupid switch for the map lights so if you just nudge it your battery is screwed if you don't notice they are on.. I use a tender for a couple days or anything longer.....never have on another car in over 50yrs of owning many many...jmo
[QUOTE=Jimmy W1;1596743801]2nd this. Alternators aren't like the old generators. They won't pick up (charge) a dead battery. You should charge it for several hours when you buy a new battery. Preferably overnight.
[/QUOTE Wrong: I've charged my battery on my vette and my classic car many times after a jump start.is that not what the alternator is for....I remember back in the day when i had a lot of used cars with the generator and a 6 volt battery and to get a charge i would have to run the engine at a higher rpm. Not all of us have a battery charger.Would not do any good anyway,because i live in a apartment with covered parking with no ac power.
#33
Same issue. I just replaced the battery in our "13, but the first replacement battery was dead after a few days--long story, no parasitic drain, but bad battery. The second one seems to be working well.
#35
I have a 2013 sits in my heated 4 car garage. It has sat for better than 3 weeks and it fires right up. My 2003 could sit for that long and would have no problems starting it.
I feel you have a draw on your battery. As an example; I have my 68 Camaro (I am the only owner) in the same garage. When I park it, I discount the negative post on the battery. I had to replace my battery last summer, after 16 years on a auto zone battery. Old cars have drains due to shorts in old wiring. So I beat the system by discounting the negative.
Now we can not really do this with our vettes, but you could use this as a trouble shooting method to prove the car drains the battery and that the battery is not bad.
Good Luck in trouble shooting !
#36
How about dirty battery terminal connectors? My battery went dead (7 yrs. old now and 2nd one). Tried to jump it no success then I cleaned the terminals and it started right up after jump. But a week later battery dead at 10 volts....
Autozone did a free battery test that says it's 99% good and charging system works fine.
