Exhaust Enhancer Plate
Hello.
I was wondering if it is easy to put on a exhaust enhancer plate?
I found one I like I just am not going to buy it if it is difficult to put on.
I am a female trying to add to my car.
Berly (02-27-2018)
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
You loosen the hanger bolts enough to slide it in sideways the up on the other side, then tighten the hanger bolts. Very simple process.
Berly (02-27-2018)
Berly (05-21-2018)
Berly (05-21-2018)
Berly (05-21-2018)
I think it is great you wish to begin some mechanics.
Very easy install.
This is from memory.
Again really easy.
Typically these plates are slotted and slide under the bolts.
1) Lift car...only a foot needed, there is plenty of room, so you can slide under the car on your back. Don't forget to use a safety/ jack stand...that is good practice to follow.
2) Look for the two retainer bolts between the mufflers on the bumper reinforcement.
3) Regular socket, extension, ratchet or a open/ box end wrench. I believe it is 1/2 size.
4) Loosen the bolts, or remove the bolts, slide into the plate, add some blue Loctite to the bolt threads (optional), tighten the bolts to 18 foot pounds.
5) Lower the car, smile and take a picture of you new plate.
Welcome to the DIY mechanic club.
Very easy install.
Again really easy.
The following 2 users liked this post by Kenny94945:
Berly (05-21-2018),
gotthafever (01-30-2019)
If you're on the slim side you probably won't need to raise the car, I can get at it without lifting just by parking the car with the rear wheels at the end of my garage floor by the door and the rear of the car overhanging the sloping driveway. Just make sure the car is in gear (or Park) and set the hand brake. Never hurts to chock a wheel if you're under the car also.
Berly (05-21-2018)
