Changing rear end fluid
Pro Mechanic
Received 3,999 Likes
incorrect additives actually degrade (attack) bonding material of the friction material to the clutch plates.................
The wrong fluid can end up with lower break away values from the LSD clutches/faster wearing out, meaning having to tear the Diff apart to replace the packs, as well as the clutches becoming noisy again quickly as well.
Hence LSD clutch packs should have a 100ftlb break away value each side.
Bluntly, was a fad not long ago to use Redline fluid for the diff since it was slicker, ending up with lower clutch pack break away values/ peg leg burn outs, as well the diffs having to be pulled apart to replace the clutch packs that worn out prematurely as well.
Same goes for the Trans, since the T56 syncros discs ring pads require the correct fluid for them to work/ not wear out prematurely as well.
I understand that GM came out with a SB and changed the fill. I would assume that at that time, manuals were updated.
If I had the SB at the time, I likely would've saved some $$ and aggravation and forgone the additive. As it it now, the additive and new fill have worked fine. No more clicks in the rear end.
dmk0210 (03-07-2018)
My 2010 owner's manual makes no mention of an additive in either the Recommended Fluid section (7-10) or the Rear Axle section (6-55).
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
^^ I recall it was the second change of fluid type/conditioner that was the final fix and if I recall correctly it did occur sometime in either early or late '08. That means additive already in the fluid, no separate additive needed or wanted. Mine being one of the first built in the model year (July, '07) it was subject to the redo and was done at the dealer sometime in early/mid '08.
One major tip for the do-it-yourselfers here.
Always loosen and remove the fill plug first, before removing the drain plug. Partly, that helps it drain better, but the most important reason is how bad it sucks to break your wrench or round out the seized up fill plug after you've already pulled the drain plug and drained the lube out of the thing. Don't ask me how I know this.
PS. Using a vacuum device at the fill plug hole completely avoids any risk of that issue.
The following 2 users liked this post by C6_Racer_X:
marcoturbo (04-10-2021),
Vet Interested (03-15-2018)
Going to use my MityVac to vacuum most of the fluid, then remove drain plug for the rest.
(05 drain plug above rear spring) Hope this eliminates mess on the garage floor. GM LS fluid for fill.
Heck...the more things (tools) you have to handle during any job like this seems like it would be more apt to cause problems. Just get a big drain pan and drain it all out the drain......
So if i'm getting no chattering or binding then i'm probably good to go ??
Pro Mechanic
if you did add the "additive" previously, that was never stated anywhere that I saw...............
you may not have had it installed for a long enough duration, or utilized the clutch plate operation enough to cause any detrimental effect.............. or accumulated enough mileage for it to potentially impact the bonding agents on the friction material..........
too many unknowns or not enough information provided to say with 100% certainty
my '08 owner's manual (cut and paste)
What to Use
To add lubricant when the level is low, use
SAE 75W–90 Synthetic Axle Lubricant (GM Part
No. U.S. 89021677, in Canada 89021678) meeting
GM Specification 9986115. To completely refill after
draining, add Limited-Slip Axle Lubricant Additive
(GM Part No. U.S. 1052358, in Canada 992694). See
Recommended Fluids and Lubricants on page 6-11.
Then fill to the bottom of the filler plug hole with
the Synthetic Gear Lubricant
6-11
Rear Axle
(Limited-Slip
Differential)
SAE 75W-90 Synthetic Axle
Lubricant (GM Part No. U.S.
meeting GM Specification 9986115.
With a complete drain and refill, add
4.7 ounces (140 ml), or 6.8 ounces
(200 ml) for ZO6 Models, of
Canada 992694) where required.
See Rear Axle on page 5-51.
it's my understanding that this was superseded by a service bulletin. However, the GM additive is still available and the service fill cured my rear end "clicks" approx 2 years ago.
What to Use
6-11
Rear Axle
(Limited-Slip
Differential)
dmk0210 (03-08-2018)
#33
#34
I tried to find the service intervals or recommended mileage for changing out the Diff oil but no luck, probably missed it so what say you gurus about this.
My 2011 GS has 30,000 mi. and obviously about 6 years and as far as I know never been changed. Having no problemos BTW
NSF
NSF
#35
should be good to go......................
#36
Note, spindle nut is torqued to 140ftlb, and is loctite in place, so it will be the axle turning via the nut, and should not be the nut turning on the axle shaft at the 100ft lbs that the clutch pack each side should allow that axle to turn indepently of the other tire side.
The correct break away torque value for the LSD clutch packs to allow each axle side to slip independently of the other side is 100ft lbs.
So that note, once you have checked one axle side, do the same for the other side, and check that side break away value as well.
C6 diff, and you have a clutch pack on each side, for each axle side.
#38
NSF
NSF
FYI, the differential gets pretty hot on the race track, hence the frequency.
#39
Katech recommends changing it often on tight road courses. I'd imagine autocross or tight roads street driving would also exercise the diff quite a bit.
