Front Camera, Microphone and GPS Mounting Videos
Old 01-21-2018, 02:16 AM
noturbo408
noturbo408's Avatar
Default Front Camera, Microphone and GPS Mounting Videos
Sorry, the videos are very rough outlines of how I am mounting each one of these components, but hope they help anyway.
Specs:
2011 Grand Sport
No Bose
Deck - Kenwood DNX573S
https://www.amazon.com/gp/product/B01I2NUU2Y/ref=od_aui_detailpages00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01I2NUU2Y/ref=od_aui_detailpages00?ie=UTF8&psc=1
Harness - PAC RP5-GM11
https://www.amazon.com/gp/product/B00DHUA9VA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00DHUA9VA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Stereo Kit - Metra 95-3304
https://www.amazon.com/gp/product/B000K50GEU/ref=od_aui_detailpages00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000K50GEU/ref=od_aui_detailpages00?ie=UTF8&psc=1
Rear Camera - NOAUKA Waterproof IP68 Night Vision
https://www.amazon.com/gp/product/B06XNM7GNS/ref=od_aui_detailpages00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B06XNM7GNS/ref=od_aui_detailpages00?ie=UTF8&psc=1
Front Camera - Car Camera Front and Back,Chuanganzhuo Car Reverse Rear View Parking Backup Camera
https://www.amazon.com/gp/product/B01C56G1P4/ref=od_aui_detailpages00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01C56G1P4/ref=od_aui_detailpages00?ie=UTF8&psc=1
Front Camera Video:
Microphone Video:
GPS Video:
The following 6 users liked this post by noturbo408:
Callaway DrDon (01-21-2018), JohnRR (08-27-2018), neoattilahun (12-12-2020), PuckDracon (01-21-2018), tjaved22 (04-12-2019), zaragoza (08-22-2020) and 1 others liked this post. (Show less...)
Old 01-21-2018, 10:36 AM
PuckDracon
PuckDracon's Avatar
The front cam vid helped a bunch. I will be doing this Monday(along with a head unit, mic, and rear cam) and haven't taken a look at wiring it in yet. This gave me an idea what to look for .
Thanks!
Old 01-21-2018, 11:13 AM
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
you're not going to get crap for a signal with the GPS antenna upside down, it needs to be mounted upright, not upside down or on it's side.
noturbo408 (01-21-2018)
Old 01-21-2018, 07:45 PM
Callaway DrDon
Callaway DrDon's Avatar
Getting ready to do a Kenwood install. Thanks for posting
Old 01-21-2018, 10:38 PM
noturbo408
noturbo408's Avatar
Just tested the GPS even with the receiver just stuffed into the hole beside my center speaker and it seems to be working fine. I'm going to keep it there for now until I start experiencing any signal issues.
Old 01-22-2018, 03:40 PM
noturbo408
noturbo408's Avatar
Here is a rough rear camera video:
The following 2 users liked this post by noturbo408:
Old 01-22-2018, 09:35 PM
Callaway DrDon
I am sure this is a dumb question, but are the parking guide lines on/from the camera or head unit?
Old 01-22-2018, 10:06 PM
doomi
doomi's Avatar
Not a dumb question. Depending on what you buy it could be an option on both. My head unit and camera both display the guides, but I prefer the camera setup so I disabled it on my head unit.
Edit: you can also usually disable the camera guide lines by cutting a wire loop.
Callaway DrDon (01-23-2018)
Old 01-22-2018, 11:47 PM
noturbo408
noturbo408's Avatar
Yes, what doomi said. I disabled both lines because I don't feel like they help. They just confuse me even more. I made the mistake of cutting both wire loops on my camera so now I have a regular display on my rear camera instead of an inverted one though. Now I have to strip the wires and solder them back together again.
Old 01-24-2018, 07:39 PM
Callaway DrDon
One more question......are back-up and front view cameras interchangeable. I see multiple back-up cameras listed but only a few listed as front view.
Old 01-25-2018, 12:39 AM
noturbo408
noturbo408's Avatar
I don't think they're always interchangeable. Some front cameras won't have the ability to invert the image. My rear camera comes inverted and can be set back to normal, so that one is interchangeable.
Old 01-28-2018, 11:59 PM
noturbo408
noturbo408's Avatar
Also added a cigarette lighter replacement that contains a USB and HDMI in the center console.
Amazon Amazon
Old 01-29-2018, 04:23 AM
User Omega
User Omega's Avatar
I need to get my front camera hooked up.
Old 02-05-2018, 12:09 AM
noturbo408
noturbo408's Avatar
Another tip. Although I got all the channels that I normally listen to, but I was getting static on a few of them. I bought an antenna booster (attached) and it cleared up the static.
You can buy it here:
https://www.ebay.com/itm/220831228507
Old 02-22-2018, 04:19 PM
Doc_Ox
Doc_Ox's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Great info. Thanks for sharing. I ordered the same Front Camera that you recommended above and now I need to install it.
Where did you specifically tap into for Power (Red Wire) and where did you ground it (Black Wire)?
Also, how is it performing so far? Good picture quality? Withstanding the elements ok?
Thanks!
Old 02-22-2018, 05:32 PM
madsonp
Support Corvetteforum!
madsonp's Avatar
Received 1,766 Likes on 1,173 Posts
Thanks!
When I did my cameras (front and rear) I just tied into the power and ground wires of the stereo, it works just fine.
Old 02-23-2018, 12:21 AM
noturbo408
noturbo408's Avatar
Thanks!
On the camera there is a red plug that you can plug to another wire that contains a red and a black wire. Connect that red wire with the red wire on the yellow RCA cable. At the opposite end of the RCA wire, there is another red wire. I connected that red wire to the red wire from the PAC RP5-GM11.
As for the black ground wire, I connected it to a bolt that is right by the drivers side hood strut. See time 2:11 on my youtube video. You'll see that there is a wire with a blue fitting right underneath the nut. That's my ground wire.
As for the camera, it is holding up so far. I never drive my car in the rain, so I don't know how it'll impact the camera. I have washed the car before though and no issues after the wash. Picture quality is fair. Not the greatest, but it isn't bad.
To Front Camera, Microphone and GPS Mounting Videos
Old 02-23-2018, 05:47 AM
Whis9
Whis9's Avatar
nice info
Old 02-23-2018, 08:25 AM
Doc_Ox
Doc_Ox's Avatar
Thanks for the tip.
Got it. Thanks. My initial confusion came from the long RCA cable that has short red wires on both ends. The red wire doesn't appear to travel the entire length of the cable (on the exterior), but it must travel the entire length inside of the insulation. I feel quite silly for not realizing that initially.
Old 08-06-2018, 02:42 PM
GaryB106
5th Gear
GaryB106's Avatar
Gary Bates. I installed a similar Kenwood stereo from Crutchfield in my base model 2011. I assume that the mic right next to where’s your mounting yours is for the OnStar service. I have no idea why the wiring harness couldn’t include that mic, but Crutchfield said it can’t.
I was wondering if you thought about splicing into it, or if it’s even possible. I’m thinking about giving it a shot, at least for appearance, but the outgoing audio quality is poor. Crutchfield upgraded the mic but strongly recommmend I move it closer
Quick Reply: Front Camera, Microphone and GPS Mounting Videos
