Rpm
I thought I had a chart for the 05 A4 automatic tranny, but the only chart I've got is for the later years A6 tranny. That tranny would be at about 1500 to 1600 rpm at 65 to 75 mph.
I'm guessing the A4 would be close to that.
Race Car Tech
Same car...IIRC at 70 I'm at about 1800 RPM's...
Edited...after looking at the comments I realize I didn't mention mine is a Z51, that would make a difference!
Received 1,136 Likes
If one really wanted to know without actually driving it, check the A4 hi-gear ratio compared to an A6. If they're the same, then the RPM would be the same *IF* the diff ratio (and tire diameter) is the same.
But screw all that math, I do math for a living. It would be a lot easier to just drive it. What difference does it make anyway?
The OP wasn't specific, but maybe he is wondering after driving it if his rpms should be different than what they are. That's a guess on my part because he really didn't give a lot of info. Maybe he's got an engine problem and is hitting 2000 and felt like it was working way to hard?
I'm guessing he's getting about the right rpm's (1500-1600 at those speeds) but thought it was way too low. Probably he's not familiar with V-8 engines. Most cars these days turn much higher at "highway" speeds.
Received 3,651 Likes
2016 C6 of Year Finalist
Then the environmentalists and safety tyrants infiltrated Washington and fuel economy became mandatory so overdrives came back, although now not free-wheeling. I noticed in my A6 Vette that 4th is very close to 1:1; 5th and 6th are both overdrive. (On an old style stick, in high gear the input and output shafts were locked at 1:1. In high gear, the only reduction between the crankshaft and rear wheels was via the diff ratio).
My best friend was driving my Vette a couple of summers ago and he noted how low the RPMs were at highway speeds (12-1400?). I told him that to compare RPMs with "old" cars, you would have to check the C6 RPMs in 4th -- it being the closest to 1:1.
Ha, I had a '70 Roadrunner 4-speed with 4:10s. As I recall, in 4th I think it cranked about 3,000 at 60 MPH (4th gear was 1:1).
Something like that anyway. I'm on my 4th (5th?) drink (no guarantee on that) so I could be off.
Actually they turn much lower. They outlawed overdrives (late '50s?) from the danger posed because they free-wheeled when you let off the gas, possibly overloading the brakes.
Off topic somewhat, I thought all 4 bangers were high revvers on the highway. Even my 12 300C Hemi was around 2500 RPM at 80mph. Bought a 16 Malibu with the 2.0T and 80mph is about 2000rpm and it has enough grunt to make it over small hills even in 8th gear.
Z51 or not is the key for 2005 as that is about a 15% difference in gear ratio. I think 4th gear in the A4 is the overdrive gear where in the A6 it is 1:1. I think A6 gearing in 6th gear is about .5:1.
thats exactly what I stated.my stock MSR car came with the optional 3:15 gear.the 3:15 gear was available on all 05 C6 auto cars
G90 is the RPO code for 3:15, or Z51 for the Z51 performance package.
In my non-Z51 auto 2005 Corvette with stock tires, turns 1500 at 60 mph. So 65 mph is around 1600 rpm. 70 would be 1730 rpm.
Also here is a calculator. http://spicerparts.com/calculators/t...rpm-calculator
