Battery Charger Wiring Route
Hi Rocket Riders !!!
I have a 2013 427 Vert and I want to connect a Cen-Tech 12 volt Battery Charger/Maintainer. My Battery is in the trunk and my power source is next to the Passenger door and drops down from the ceiling. I want to route the connection ( two 18GA Wires ) from the trunk to the right side of the passenger seat, so I can simply open the door and plug in the charger.
My problem is routing the wires from the trunk to the side of the passenger seat. There is no obvious route so before I started pulling on the carpet and speakers I thought I would call on the vast experience and knowledge of the Corvette Forum for the best route of the wires.
Thanks in advance for any suggestions
Ed Cackowski (08-11-2017)
There is no need to run wires to bring power to the front of your car. Read your manual on how to jump start your car. There is already a remote positive and negative terminal at front of the car. This is where you would hook up jumper cables should you ever need to jump start your car. You can easily use this points to hook up your battery tender.
Or you can do was most of use do, use the cig lighter.
It amazes me how.l many gadgets and wiring people do when you can run the wire under the door, put the wire in the little groove that's there, and close the door. I run mine across the driver's seat and out the door so I can't forget it's plugged in and drive off like I've seen more than enough times on here.
I just did mine this week, Connected positive to lug next to fuse box under hood & negative to bolt on frame towards front on passenger side (I had to splice in a few extra ft ) then fished it through an opening in the lower front passenger side ( NO holes to drill ) then out the front of grill, works great I can fold it back into an opening in the grill when not in use, much easier than opening hood or door all the time..
I am having the same issue with my cig lighter. It is starting to get loose and not making a good connection all the time. So I will probably have to wire in a different setup as well.
I simply open my hatch, hook up the charger to the battery with the alligator clips, then plug in the charger to the outlet on the wall on the passenger side of the car. Done. I also put a note on my driver side window "battery charger" so that I don't forget to unplug it before driving off. Been doing it that way now for 5 years.
I used the Cig Lighter for several years until recently when the plug would not stay in .That's why I am looking into permeate wiring. I switched to the plug in the console and it works fine . My problem is that my power is on the passenger side of the car and the console door opens toward the driver side so plugging it in is a real pain . I was told I could replace the cig lighter but that is more dash disassembly that I want to get into. Thanks
Mag Connector
I chose to use the magnetic connector route for tending to the battery.
I wanted a quick and easy way to connect and disconnect the tender, and a way that if I forgot to disconnect,
it would disconnect itself if I drove away and forgot to disconnect it first.
The product I chose is the Mag Charger available from Corvette Central or Nakid Parts .
The product:
Pictures of my installation – installation time was under an hour:
Fully connected to battery tender
Receiver when disconnected (driving condition)
Unit connector head that connects to Battery Tender and it's mate on the car.
Wiring to battery inside engine compartment using 1/2” slit loom –
this conceals the connection between the Battery Tender battery
connection and the magnetic plug.
I chose to wire directly to the battery – alternatively you can also wire to the fuse box as others have done -
especially if your battery is in the trunk
The product:
redcycle13 (12-29-2020)
