Stuck in Park
Stuck in Park
Ive done a lot of reading on older posts about this. Has there been a better fix to come up and repair this besides taking the console apart and breaking or wiring it back because GM is to cheap to come up with the correct fix or a recall. I have a 2005 Base and it seems it is a bigger problem with 2005 than any other year. I had a C5 before this and it had the column lock problem, but they did come out with a fix for that. And the after market fix was way better than the GM fix. Anybody that can give me some updated info I would really appreciate it.... Its not know fun being a couple hundred miles away from home and not knowing if your car is going to move or not. Ive been lucky It has only happened to me twice and both times in my driveway. And putting it in accessory mode only works if the solenoid isn't stuck......
Race Car Tech
Most have tied the locking pawl back, including myself. There was a recent thread on the subject that pinpointed the problem with the tin micro switch.
Either way, you would have to remove the radio surround console to get at either solution of your liking.
It's not that difficult to do at all.
Here is that most recent thread.
https://www.corvetteforum.com/forums...use-found.html
No doubt the pawl tie back method is the best for an absolutely sure fix.
FWIW
I cleaned the mechanism and lubed everything in the area with "dry teflon lube" and haven't problem since ( Full disclosure: OK once, but a slight wiggle and no problem.) in 2 1/2 years.
If I have to get in there again I'll probably add a wire to the center storage area, that some have recommended, to manually pull the pawl back. Which I think is the best solution.
FWIW
After reading the most recent threads. I ordered the switch from Radio Shack. I also read there's a way to just pull up the boot to get access to switch and push boot back in when finished. Anybody try this. Makes since that its a switch. GM don't make any money changing a 2 dollar switch but a 1000 bucks to change out a shifter.
Received 1,137 Likes
I still don't know if the pawl is accessible that way, but it's no longer a problem.
Some have fixed the problem by a "pull" device in the center console.
I fixed the problem with dry teflon lube ( at least for the last 2 years ) . So what's the right answer? I think the problem is dirt, but w/o question the answer is to pull release/or remove the pawl.
Heres what Im going to replace. Further research and repairs have shown that this switch does wear. Which is why if you push the shifter forward it will release the shift lock. For safety reasons, lawsuits, and future sale of the car I will not hack **** up.
