Wheel Spin
Old 06-28-2017, 10:19 PM
Adam Cifonelli
Adam Cifonelli's Avatar
Default Wheel Spin
So Ive had my Vette for a few weeks now. Finally feeling comfortable to go WOT. Problem is no matter how slowly I rollin into 1st-2nd I cannot escape wheel spin. Is it just as simple as the stock Eagle RFs not hooking? Or is there just too much torque to avoid spinning?
Edit: On the road that is... not track.
Old 06-28-2017, 10:27 PM
Ron'sGS
Ron'sGS's Avatar
The Good Year Eagle tire's are terrible, especially if they're old.
Old 06-28-2017, 10:33 PM
Adam Cifonelli
Yeah.. thats what I figured. I think im going to get FireHawk Indy 500 are what I think Im getting. Cheap and great reviews.. $600 for all 4 on tirerack.
Old 06-28-2017, 10:44 PM
J.Moore
J.Moore's Avatar
I don't think any street tire is gonna bite on our streets with these LS engines under the hood. Probably why you see alot of Vets off the road and into trees. Car gets away from you FAST.
It was hard enough getting bite with my 69 Camaro on the track with 14x32 medium compound drag slicks on a PREPPED starting line. And it was only about 550HP small block 355.
Old 06-28-2017, 10:54 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
I think you see a lot of Vettes running off the road because of the idiot drivers. I have watched, and listened carefully, to many videos of epic Corvette wrecks, and the common thread is that the drivers don't lift when in trouble, or get back on it before they are out of trouble.
There are several tires noted on this forum as having sufficient grip to handle a decent launch with the base motor. Adding more power does make it much tougher, I am sure. Mine is base, and I get good, hard launches on my Hankook's.
Old 06-28-2017, 11:06 PM
Mike's LS3
Mike's LS3's Avatar
It's about pedal management and knowing when to lift your foot off the gas just enough to regain traction. Knowing your car's traction limits and adjusting to what the tires can handle no matter what tire or how much HP you have.
Old 06-29-2017, 10:56 AM
Dcasole
Dcasole's Avatar
Received 2,250 Likes on 1,639 Posts
And add a set of Michelin Pilot Super Sports
Still spinning but running very low 12's with them
It's well known that stock Goodyear run flats suck...
Dave
Old 06-29-2017, 04:42 PM
Ward Cleaver
Southern Piedmont Area
Support Corvetteforum!
Ward Cleaver's Avatar
Indeed, especially idiot drivers who turn off their traction control.
Regards,
-Ward
Old 06-29-2017, 05:06 PM
windyC6
windyC6's Avatar
How bout that button on the console. I think its for "traction control". Most people seem to agree that it's still about the best way to launch your car under most circumstances. I dunno...maybe its just me....
Old 06-29-2017, 05:41 PM
Dcasole
Dcasole's Avatar
I don't know about your car but I do use traction control and yes they still break loose .....takes a special touch to get it out of the hole even with traction control and great street tires if you are making any kind of power ...
Dave
Old 06-29-2017, 05:42 PM
Adam Cifonelli
Yeah. I've messed around with it off and on. I think leaving it on is best. But people love that "Competitive" mode.
Old 06-29-2017, 05:43 PM
Adam Cifonelli
Dave
I think my issue if just that the stock Eagles are terrible. Id prob notice night and day difference when I put on the Firehawk Indy 500s im going to order. 600 for all 4 is a steal.
Old 06-29-2017, 06:21 PM
Dcasole
Dcasole's Avatar
With my street tires I blow them away on launch and again on the 1st to 2nd shift in competition mode...scary , real scary until I get drag radials i am leaving it on
Dave
Old 06-29-2017, 06:28 PM
86SC
86SC's Avatar
i'll give my thoughts...
i have a supercharged 3rd gen camaro makes 420 to the wheels, i put on some mickey thompson ET street tires to have traction. they don't spin unless i want them to.
just bought a 2010 grand sport with eagle F1 supercar tires 325's i was surprised how they break loose with the traction control on... this was around high 50's to 60 degree temps, they are much better at higher temperatures. when they are done i'm going to try some michellins until then i find myself just mashing 1st gear to break a little sideways i learned with the vette you have to roll into the throttle.
Old 06-29-2017, 07:20 PM
EnviedC6
EnviedC6's Avatar
Honestly, I had great results out of Bridgestone RE-11 on a 19x11 with 325/35/19 size. It bit great all the way down till recently. I just swapped them out for some DR's and they were at 2/32nds. I am pushing just over 450rwhp.
Old 06-29-2017, 08:03 PM
Adam Cifonelli
Def. Although at 30 in 2nd gear I can punch it and hook up and that 424 torque hits u soo solidly. That def the most satisfying part Ive found driving so far.
Old 06-29-2017, 09:58 PM
Naldinator
Naldinator's Avatar
Dave
I have personally witnessed him do just this.
Either his tires suck or he has a bad connection between his brain and his right foot.
To Wheel Spin
Old 06-30-2017, 07:18 AM
Dcasole
Dcasole's Avatar
Need to get those drag radials like u
Dave
Old 06-30-2017, 07:31 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,845 Likes on 1,802 Posts
Dave
This is good to hear as I have the same tires. I plan on testing them out once the weather cools down.
Old 06-30-2017, 10:44 AM
saplumr
saplumr's Avatar
Received 1,251 Likes on 895 Posts
That's usually driver error more than tire issue.
Quick Reply: Wheel Spin
