A6 won't shift out of park - root cause found
#261
This one was on me. I’ll share this in case someone else has this exact same problem or something similar. The issue was the soldered connection to the new switch I previously replaced loosened. I’ve soldered 1000’s of connections, so embarrassing to say that, but that was the issue - but again, want to share to let others know that this fix really does work (as long as you solder correctly!) and that sometimes issues can come up. Thanks to everyone’s contribution on this thread and forum!!
#262
The following 2 users liked this post by Big Jay E:
Trebor (11-09-2022),
ValenciaOrange (05-08-2023)
#263
Thanks I am not one to cut things off ….I am giving this a try. I am also putting a momentary switch in the ashtray area so I can bypass the switch just a backup so I don’t get stranded. Thanks for the info!
#264
Replacing the switch
I know this is an old thread, but the problem still keeps cropping up.
I'm planning to replace the switch. Since the new one has spade connectors, and as already noted, we should use the Normally Open NO and the Common connectors, does it matter which wire goes to which connector? The blue and the orange wires.. does it matter which terminal they attach to?
thank you.
This thread could probably qualify as a sticky note.
thank you.
#265
thank you.
thank you.
#266
Mike Green9 (09-11-2023)
#267
This good but
I came up with this idea and it worked fine for me.
I used a Bic pen tube and cut it to size(length), with the pawl pulled all the way back. Then sliced the full length open,
so I could slip it over the rod. Then for safe keeping, I put a tie on it.
The pencil is pointing at the Bic pen tube and tie. I cut the long tie end off after the shot was taken.
This way nothing is drilled, wired or cut off and when removed is in stock condition.
I plan on doing a post on the whole job in a bit. Hope this helps.
Why don't you try to fix push button for release that shifter safety when you need to get out of the park position and it will return to it's normal function as you push to park.
I think this will be beter😁
#268
My way passes them all and can be done without damage, so it can be corrected later if needed.
Others have their way, I've chosen mine. Good luck with yours.
#269
You got a point
As I said my dear friend.
And as you said so, there are different problems may case this No shifting from park.
As I face with my c6 gear shift ting.
Frist the problem was with damage kbon which was broke to pieces and I solve that with installing a Cadillac **** after making grove inside so it will go through the original shaft.
The I faced that the push shaft was stuck hardly, and that was because of pin across the shaft which come over the returning spring. ( the pin was getting out of its place.
And after all this I done and solved this problems.
I am facing that the solinoide luck up is not functioning as it should be.
Checked the fuse and found OK, checked the relay also was OK, and I got conclusion that the solinoide is not OK.
And now I will do something for temporary to get released from parking with my idea.
Your idea is good for temporary, but you got to keep in mind that doing it your way will case easy shifting from park without safety luck.
And any one can shift the gear such as kids or thief.
And if only you know the way for unluck from parking position it will be more secure for you 👍
Wish you lick with you good work.
And wish to exchange knowledge with you in future ❤️
Mr. Jean (09-11-2023)
#270
Thanks everyone for this information, priceless!
I ordered 4 switches from eBay for $10 delivered. Removed center console, left the shifter in place and worked around it. Not too bad of a job.
The actuator is slightly different than the factory switch. A little adjustment is needed. Do this and check with a meter before you reinstall the console, I did and really happy that I did.
EDIT: The switch that I removed has 52 ohms resistance, constant.
rpw1690 (02-15-2024)
#271
I have this same problem where sometimes I can't shift from park, so I've been reading this thread (and have the center console removed on my C6 in the garage at the moment).
Definitely looks like the root cause is the micro switch, and I have new microswitches on order from Amazon that I'm planning on soldering in.
Looks like someone created a harness that you can replace that has a version of the microswitch that has a roller on it - stumbled upon this video when searching for the issue:
Sharing the custom harness that they're selling for those that don't want to solder:
2005-2013 Corvette Automatic Shifter Repair Harness FREE... – Corvette Parts Center
Quite a bit more than I paid for the switches, but this is probably a simpler DIY solution if you don't want to solder.
#273
I have a 2005 with the A4 automatic transmission and have the problem with shifting out of park. Does anyone know if the part #SS-5GL13 switch used to repair the A6 automatic will work to fix it. I did the what in the world is going here stuck in a parking lot the first time and almost started to kill the shifter but it finally shifted. It's done it a few more times and is time to fix it.
My Corvette likes my money
Anyone have the part number for the switch with the roller?
rpw1690 (02-19-2024)
