Factory installed xm equipment
I'm determined and will not give up; I'm engineer by trade and I know there is a solution.
Has anyone installed factory xm equipment into a C6 that did not come with factory installed xm?
I have everything installed and the radio is not recognizing the xm box. The dealer is not helpful.
I think extrapilot hit it ... somebody with a Tech II needs to check the box to tell the HU there is XM out there.
VIS report
Go to a local GM dealer with your VIN and request the VIS report for Warranty and Build history.
If you have the XM from the factory, it will show up on the Build history.
