C6 fuel tanks
Itshakes (02-09-2017)
I think...seems overly complicated to me as well, but pretty sure I've seen this explanation somewhere on this forum. I just don't have the energy to search for it.
C6 to go is correct
Passenger side tank uses siphon to pump into drivers until it is empty. Electric fuel pump in drivers side that pumps up to motor. So at 1/2 way, passenger tank should be empty and drivers tank full. When you fill up from empty, you fill drivers side until it get to top and spills over into the passenger side from the crossover tube.
Received 1,121 Likes
Here is the shop manual version. I read up on it when my sender was failing:
The fuel system is a returnless on-demand design. The fuel pressure regulator is a part of the fuel tank module, eliminating the need for a return pipe from the engine. A returnless fuel system reduces the internal temperature of the fuel tank by not returning hot fuel from the engine to the fuel tank. Reducing the internal temperature of the fuel tank results in lower evaporative emissions.
Two fuel tanks store the fuel supply. An electric turbine style fuel pump attaches to the fuel tank module inside the left fuel tank. The fuel pump supplies high pressure fuel through the fuel filter and the fuel feed pipe to the fuel injection system. The fuel pump provides fuel at a higher rate of flow than is needed by the fuel injection system. The fuel pump also supplies fuel to a Venturi pump located on the bottom of the left fuel tank module. The function of the Venturi pump is to fill the left fuel tank module reservoir. The primary fuel pressure regulator, a part of the left fuel tank module, maintains the correct fuel pressure to the fuel injection system. The left fuel tank module contains a reverse flow check valve. The check valve, the primary fuel pressure regulator, and the secondary fuel pressure regulator maintain fuel pressure in the fuel feed pipe and the fuel rail in order to prevent long cranking times.
The fuel pump also supplies a small amount of pressurized fuel through the auxiliary fuel feed pipe to the siphon jet pump inside the right fuel tank. The pressurized fuel creates a Venturi action inside the siphon jet pump. The Venturi action causes the fuel to be drawn out of the right fuel tank. The fuel transfers from the right fuel tank to the left fuel tank through the auxiliary fuel return pipe. The auxiliary fuel return pipe inside the left fuel tank contains an anti-siphon hole in order to prevent fuel from siphoning from the left fuel tank into the right fuel tank. Both the auxiliary fuel feed pipe and the auxiliary fuel return pipe are located inside the convoluted stainless steel crossover hose.
The right fuel tank module contains a secondary fuel pressure regulator. The secondary fuel pressure regulator has a lower set point than the primary regulator in order to allow fuel to flow to the siphon jet pump on the right fuel tank module. When the engine is shut off, the pressure in the feed pipes immediately drops to the secondary regulator set point. This prevents the siphon jet pump from operating and in turn prevents the equalization of the left and right fuel tanks. The secondary fuel pressure regulator maintains fuel pressure in the auxiliary fuel feed pipe which reduces the time to prime the siphon jet pump. The pressurization also reduces fuel vaporization and boiling in the auxiliary fuel feed pipe.
This shows how the fuel tanks are laid out- (How-To fuel filter replacement)
https://www.corvetteforum.com/how-to...-filter-368703
skeeter131 (02-11-2017)
So the fuel from the right hand tank is pumped to the cylinders on the right side of the engine and the exhaust from those cylinders comes out the right side exhaust pipe...and the same thing happens on the left side of the car.....
Itshakes (02-11-2017)
Actually its the opposite. Just like the exhaust, there is an x-pipe so it swaps sides on the way up so it can match the exhaust flow out the back.
OP - More than you ever wanted to know about the fuel system - http://www.hessh.de/Corvette/FuelTankSystem.pdf
This has been discussed many times. The first I recall getting it correct was about 10 years ago - https://www.corvetteforum.com/forums...uel-tanks.html This site's search function is pathetic but just add site:corvetteforum.com to a Google search and you get much better results.
Received 4,741 Likes
Has anyone done a mod that fills both tanks at the same time? Mine is a nightmare to fill, I'm assuming because of trapped air. I have to pull back on the rubber seal to let out trapped air while I pump. Sometimes it takes as long as 15 min. to fill up.
Stupid Cali regulations!
On right hand drive corvettes does everything reverse in operation... Does the primary become the secondary and then the secondary becomes primary then the right exhaust becomes the primary exhaust and the left exhaust becomes the secondary... Who's on first..???
