Quick shifting tips?
Just picked up an 08 z51 car with the manual trans and was wondering if anyone had some tips for learning to shift quicker in this car. I've owned a zf6 6 speed duramax but that is like shifting a semi compared to the vette. I have no issues driving the manual but just want the smoothest and fastest shifts posssible so figured I'd ask others for some advice
The best advise I could give is to drive the car for at least 10 miles to really warm up the tranny. This really makes the shifts a lot smoother.
The next thing I did, personally, is to change out the OEM knobe for a Q ball knobe. This lowers the height of the lever allowing slightly shorter shifts, which is nice.
Received 1,597 Likes
The lower box will replace all the OE bushings, which on your car are at least 9yrs old. You will have to do it at some point, may as well take everything apart once and be done with it. While you have the console out you might want to install some heat shielding on the tunnel as well.
NorthTexasPete (05-08-2022)
I'll give this a go once spring rolls along, the guy I bought it from gave me one he ordered for it a while back.
After you figure out how to shift faster you'll be asking which clutch can handle the abuse better.
